how do you know the injectors arent pulsing? have you used noid lights? check the injector fuse.
Fuse is good. but no juice at the injectors. thursday before i left town i tried a different computer and still no change. Ill be digging back into it 2morow. thanks
Fuel pump resistor? If you do a search, you may find what your looking for in more detail.
My dads car is doing the same thing... Still haven't got it working yet, if you figure it out please let me know, Ill let you know if I figure anything out
The injectors are powered by one fuse and toggled by grounds to each individually from the pcm.
If your security system is pissed off, you will typically start and run for a few moments on the prime shot that was enabled before the security on the key was checked (many models, unsure about yours)
One other thing to check is the MAF. Unplug it and give her a whirl. The maf can read improperly and cut fuel off.
yes it has a code of p1200 injector control circuit. I am not getting juice to the injectors so I put 12volts to them myself. But it still dont run that way either. so the pcm isnt grounding the injectors either. I was thinking it could possibly be the security system but there isnt a pellet in my key.
