pull pass side tire
pull balancer will need special bolt size 3 3" bolts for puller pull pulleys water pump and every thing blocking front cover
pull front cover
unbolt cam bolt slide timing set off
align new timing set
might as well replace water pump and oil pump since they are off any way
re install all the carp taken off and enjoy
