Thread: my KR
Page 2 of 2 FirstFirst 12
Results 21 to 33 of 33
  1. #1 Re: my KR
    New Jersey
    it aint staying at 22 degrees I can assure you of that. 22 deg BTDC at 4K would cook your exhaust valves and probably not give enough power to go any higher.
    id assume our engines are seeing 40-50+ deg of advance near redline.
  2. #2 Re: my KR
    Donating Users Warbeaver's Avatar
    St. Louis
    k, did a couple wot runs on my aeroforce and came up with this:
    its actually 28* timing
    o2 is 890-900
    KR is 2-3.5* KR on 93 octane vs the 7-8* on 87
    so, looks like if i had it down to 26* of timing, i would have 0* KR on 93 octane....
  3. #3 Re: my KR
    http://upload.wikimedia.org/wikipedi.../Timingmap.jpg
    last column seems pretty consistent.
  4. #4 Re: my KR
    New Jersey
    Hmm maybe i'm wrong tho? I donno, i'm going on very old old information.
    Matt : do you have any info on the timing curves the 3800 specifically uses?
  5. #5 Re: my KR
    GT Level Member GeosGP's Avatar
    Fenton, MI
    Quote Originally Posted by MrTube View Post
    It's not a curve so much as it is a map. Matt posted one there in that link. I have a few from HP Tuners if you'd like to see them.
    2004 Grand Prix GTP Comp-G
    Stock, featuring more KR than you can shake a stick at
  6. #6 Re: my KR
  7. #7 Re: my KR
    Charles City, IA
    it is static at WOT, for sure 100%.
    My wot timing log from when I started tuning.
    9.00000
    10.25000
    11.00000
    10.50000
    13.38235
    13.31618
    14.02326
    13.79851
    13.88710
    13.69444
    15.00000
    SMGPFC Two Nipple General
  8. #8 Re: my KR
    Hmmm..
    CALLED IT.
  9. #9 Re: my KR
    New Jersey
    Wow, all these years I was looking at timing advance backwords. I always assumed under load you had more advance. It looks like you can run 40+ deg of advance but not under load.
    And at the same time, I think the long mystery of why my 87 grandprix pinged BAD even on 94 octane is solved. I swapped out almost every part even the ECM at one point, it still pinged. I even swapped in different metering rods and had it rich to the point it smoked a decent amount floored, still pinged. And we're talking it pinged to the point it sounded like a diesel.
    The more you opened the carb, the more it pinged. It didn't ping idling, or under light load\cruising. The ONE PART i never changed was the vacuum sensor. I bet it wasn't retarding the timing as the vacuum dropped (load increased)
    Looks like I learned a lot from this thread
  10. #10 Re: my KR
  11. #11 Re: my KR
    Or run race gas ALL the time
  12. #12 Re: my KR
    St. Louis
    i would if it didnt run my pockets dry
  13. #13 Re: my KR
    I was kidding...its like nearly $9 a gallon here for unleaded 108 or whatever.
