Thread: Engine codes
Results 1 to 2 of 2
  1. #1 Engine codes
    CT
    Been fighting codes for about a 1-1/2 years now. 2002 GP-GT 85,000 miles. Present codes are p0102 and p0420. I know the first is for the maf and the second I believe is for the cat or maybe an o2 sensor. Here's the rub. The Cat was replaced about 11 months ago along with an o2 sensor a few months before that. The maf was replaced about 6 months ago. Presently the idle surges between 700 and 1500 rpm. It doesn't do it all the time. Mostly at initial start-up and then when decelerating off the highway. It seems to fluctuate for 10 seconds or so and then settles in at the proper rpm. Any input would be greatly appreciated.
    Thanks
    Ed
  2. #2 Re: Engine codes
    GT Level Member t24moore's Avatar
    Feb 2008
    Houston
    Try to clean your throttle body and also check your idle air control module. You more than likely have a vaccum leak somewhere if the cat, 02 sensor, and MAF was just replaced. You can spray carb cleaner around the LIM and TB to see if it stalls.
    Comp Turbo 6765 T4-ST5-A2A IC-Ported Heads-Custom Turbo headers-80 lb inj-F-Body UIM and LIM-AEM WB, TEP trans w 1" chain and Circle D TC, Dual 255s, Bilstien Struts
    WHY IS EVERYONE SO OPPOSED TO DOING A COMPRESSION TEST TO TROUBLESHOOT PROBLEMS?
  1. Help with SES codes, engine surging.
    By Fast68Camaro in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-23-2010, 06:20 AM
  2. SS intercooler and header install = engine codes
    By rascal in forum General Tech Discussion
    Last Post: 09-01-2009, 08:41 PM
  3. 97 GTP engine codes
    By willy4x4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-03-2009, 12:31 PM
  4. Check Engine Light on - Codes included
    By jcapone in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-06-2009, 02:04 AM
  5. engine light/trouble codes
    By Jakegday in forum General Tech Discussion
    Last Post: 01-02-2009, 08:03 PM
