Thread: i might top swap
Results 1 to 16 of 16
  1. #1 i might top swap
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    ok guy i think im coming around here to ur top swap so hear is the deal i will do the top swap if i dont have to change heads but i dont wanna but the ssm90 kit it cost to much so what parts would i need to top swap
    modified intake
    m90
    ecu
    injectors
    tb
    l67 fuel rail
    modular pully
    i wanna do it for under 800 bucks
    is that all and will a stock m90 fit on the modified intake thanks
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  2. #2 Re: i might top swap
    GT Level Member djrepoman's Avatar
    columbus ohio (polaris)
    Not possible w/o heads, or a lot!!! of fabricating
    2000 GT ,E85 powered, and still slow
    98 GTP Stock
  3. #3 Re: i might top swap
    Quote Originally Posted by djrepoman View Post
    i thought if i buy the ssm90 lim from zzp and a stock m90 with mps l67 injectors which i have zzp ssm90 kit with the ecu then mod a l67 fuel rail it would work as long as i know the m90 will bolt up and work with the ssm90 lim i will probably do this
    sold 97 GTP stock
  4. #4 Re: i might top swap
    ok so i just looked on the zzp site and all that needs to be done to the m90 is some dremel work to clearance for the fuel rail
    sold 97 GTP stock
  5. #5 Re: i might top swap
  6. #6 Re: i might top swap
    GTX Level Member noreasonwhyy's Avatar
    Michigan
    ssm90 kit is stupid, but run it if you'd like.
    x2.
    it all runs on one belt. plus you can only run as low as either a 3.25 or 3.4 pulley safely. can't remember exactly which
  7. #7 Re: i might top swap
    Apr 2009
    stockton ca
    theres a few top swaps on here for well under what your looking to spend with heads
    once its torn down heads are only an extra hours work
  8. #8 Re: i might top swap
    what size pully is safe im thinking 4.0 or 3.8 my mods are plog 2.5 dp ill have gtp injectors and l67 tb
    sold 97 GTP stock
  9. #9 Re: i might top swap
    Jersey
    Quote Originally Posted by nascartech View Post
    you should be fine with a 3.8". Your just going to have to tune it out.
    16' wrx sti- stock
  10. #10 Re: i might top swap
    Apr 2009
    stockton ca
    id also add in a 3"dp or get some headers
  11. #11 Re: i might top swap
    im gunna get a zzp pcm with the ss m90 tune are there any other options im using l36 heads ss m90 intake stock m90 modualur pully moded l67 fuel rail
    sold 97 GTP stock
  12. #12 Re: i might top swap
    Banned - Busted For Scamming
    Feb 2009
    You have to get the ssm90 lim and the specific fuel logs to run that, its not worth it man.
  13. #13 Re: i might top swap
    he thinks he is going to run an ssm90 lim and dremel the m90 so it will all work. riiight..
  14. #14 Re: i might top swap
    im guna get the ss m90 lim and yes dremel the m90 like what zzp does for there kit except i dontr have to pay like 500 bucks for a m90 this way lol then im gunna fab up a fuel rail at my buddies shop
    sold 97 GTP stock
  15. #15 Re: i might top swap
    May 2008
    staten island,NY
    ZZP cnc's the m90 to clear the fuel injector on cylinder 5. you need ZZPs logs because the injectors sit straight down into the intake manifold. you can change the crank pulley to run a dual belt set up like i run now. a topswap will allow you to run a full size intercooler
  16. #16 Re: i might top swap
    Apr 2009
    stockton ca
    ill say it one more time GET the full top swap heads and all easiest best route to go
  1. Top swap help
    By uNda6gT in forum Northeast
    Last Post: 03-12-2010, 12:41 AM
  2. GT Top Swap
    By cboth686 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-12-2009, 11:45 AM
  3. DIC Swap Help
    By cboth686 in forum General Tech Discussion
    Last Post: 01-01-2009, 09:14 PM
