Thread: camshaft with 1.7 rockers
Results 1 to 9 of 9
  1. #1 camshaft with 1.7 rockers
    Feb 2010
    tampa
    i was given 1.7 terra roller rockers for 50 bucks i know someone whos grand prix was wrecked etc. i now want to put in either
    ZZ Performance
    gt1
    or
    INTENSE-Racing.com: INTENSEā„¢ Normally Aspirated 3800 Camshafts
    stage 1x cam
    which is the better cam
  2. #2 Re: camshaft with 1.7 rockers
    S1x is a blower cam
  3. #3 Re: camshaft with 1.7 rockers
    Donating Users blowfishRus6's Avatar
    g.a.
    the link goes to a n/a cam......
    but, get an s1x and top swap it
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  4. #4 Re: camshaft with 1.7 rockers
    Feb 2010
    tampa
    it says s1x is a n/a cam and are the 1.7 rockers going to be ok with the camshaft
    The new Stage 1X Cam is the IDEAL aftermarket cam for use with stock heads, lifters, rock a higher stall torque converter, such as our
  5. #5 Re: camshaft with 1.7 rockers
    Feb 2010
    tampa
    i have a n/a car with oe-r lifters 105 pound springs 1.7 rollers cai 180 temp, headers downlipe cat back exuast 3 inch
  6. #6 Re: camshaft with 1.7 rockers
    Feb 2010
    tampa
    my question is are the intense cams better then the zzp cams and are they ok to use with 1.7 rockers
  7. #7 Re: camshaft with 1.7 rockers
    pretty much cant run any cams with those rockers unless you have headwork to accomodate for the extra lift.
  8. #8 Re: camshaft with 1.7 rockers
    You can mill the guides down to run it...it'll sure make more power but like Nick said...you need head work
  9. #9 Re: camshaft with 1.7 rockers
    GT Level Member ChrisGTT's Avatar
    Nov 2008
    NY
    N/A build = Pointless no offense dude. For the money you would spend to accommodate the 1.7's and a N/A cam you could easily top swap your car and gain much more hp.
    Now if you stuck on going N/A the GT1 is mild enough for your plans.
    There are S1x cams in every option from S/C to Turbo to N/A.
    Speed is an addiction the faster you go the slower it becomes.
    01 GT | Matt's new TT cam | PT-67 | 18-22psi and a couple stock trannys.
  1. Turbo camshaft
    By Bedwards in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-14-2010, 12:47 AM
  2. Camshaft?
    By paratroopermatt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-30-2009, 08:16 PM
  3. Trouble History With Camshaft Position Sensor
    By SyntheticShield in forum General Tech Discussion
    Last Post: 06-04-2009, 01:21 PM
  4. camshaft positioning sensory??
    By goyaoboya8 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-03-2009, 07:52 PM
