Thread: please help me! building motor
Results 1 to 4 of 4
  1. #1 please help me! building motor
    K EVERYONE I GUARENTEE THIS HAS BEEN ASKED? or delt with i check and could really find anything on it! plus im a little lazy my girl just bought an 01 gt. my main question is can i through a stock supercharger on it and get the ecu out of a gtp. i know ill have to gett bigger injectors which should i run and what not. agian very sorry if this has been delte with im doing this on one hell of a budget as i am building my minitruck i just want to kinda give her a little somethin besides the wheels! any info will help thanks aloT!
  2. #2 Re: please help me! building motor
    Oklahoma
    I think what you are probably looking for is a top swap. I thought one of the vendors sold a top swap kit with everything you needed, but I couldnt find it in a quick check. I dont believe you can just toss a supercharger on there because of the compression ratio differences between the GT and GTP engines.
    I would also do the HD upgrade to the transmission as well, which would consist of a HD differential, housing cover and axle.
    Im sure someone will be able to step in here and give you at least a ball park figure on what it all would run you.
  3. #3 Re: please help me! building motor
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    In short, no
    Gearing will be off causing you trans to go nuts.
    MAP sensor and BBV are missing from the stock harness.
  4. #4 Re: please help me! building motor
    Barksdale AFB, LA
    Quote Originally Posted by VinnieGTP View Post
    The L36 has a MAP sensor, just the wrong connector.
    There is a lot different between the L67 (supercharged) and L36 (naturally aspirated), though. The important stuff... heads, lower intake, upper intake (supercharger), throttle body, crank pulley, various idler pulleys, fuel rails, injectors, vacuum lines, etc.
    You can do one of two things. You can do a full top swap (which replaces all of the above listed parts):
    W Body Store Supercharger Conversion Kit
    Or you can go with ZZP's SS M90 kit which makes the install a bit more user friendly, but still expensive:
    ZZ Performance
    Read the ZZP page thoroughly as they provide a lot of information.
    2009 Subaru Impreza WRX STI
  1. Blower Motor Resistor
    By SyntheticShield in forum General Tech Discussion
    Last Post: 09-29-2017, 04:39 PM
  2. blower motor
    By Chleby in forum General Tech Discussion
    Last Post: 09-13-2017, 04:00 PM
  3. The Old and The New, Blower Motor Resistor
    Last Post: 01-29-2008, 12:31 PM
  4. Motor Trend First Look '09 ZR-1...
    By newfie in forum Off Topic Discussion
    Last Post: 01-23-2008, 07:58 AM
  5. Pics of motor
    By RED GTX in forum Turbo
    Last Post: 01-22-2008, 08:26 PM
