Thread: 01 Grand Prix has me totally baffled. Please help!!
Results 1 to 19 of 19
  1. #1 Re: 01 Grand Prix has me totally baffled. Please help!!
    SE Level Member jaysgtp360's Avatar
    anderson Indiana
    crank position sensor...car will quit while moving, in gear and tires rolling...If car quits at stop or before or after accel or decel then it is fuel related.....Other place to check before CPS....Fuel filter...if you use 87 octane, in the winter, the amount of water that can gather at the bottom of your gas tank after sitting is unbelievable.
    1. try some heat gas treatment(at least 2 bottles for full tank)
    2. Fuel filter (change it, drivers side right next to unibody frame rail)
    3. Main Ground on car and Negative and Positive terminals on battery.
    (if you have corrosion on battery or if you see green on copper wire going to car body or steel bolt then there is your problem)
    In the winter with the salt and water...corrosion is amplified by electricity...
    Potholes can jar a bad connection and cause a drop in voltage, dimming of the interior lights when turn signal is on, or brake is applied, etc...
    If it still dies then you need Crank position sensor replaced. Without knowing history of car and not having the normal visual cues....difficullt to diagnose, but most of the time if it is rolling or she is driving down the road and all of a sudden engine shuts down it is cps...
  2. #2 Re: 01 Grand Prix has me totally baffled. Please help!!
    With the car off unplug the maf. Please don't ever unplug a sensor with the car running.
    Use some throttle to get the car started and keep it running. The PCM needs to learn a little. Soon it'll idle and run decently w/o the sensor. Keep in mind you are running off preprogrammed tables and should not to WOT, but can drive it. Soon enough you should know if that's the culprit.
  3. #3 Re: 01 Grand Prix has me totally baffled. Please help!!
    westfield ma
    most of the time it is fuel pump resistor. real easy check, # 15 fuse bend bottom left tab shown in other pics and start car . that simple. that would have saved me 330.00 busks for a ne gm fuel pump
  1. Grand prix GT side skirts on 97 Grand Prix SE
    By Carnes97SE in forum How To Write-Ups/Tech Tips
    Last Post: 11-17-2013, 05:17 PM
  2. '01 3800 N/A won't start! totally confused...
    By Ragefear in forum General Tech Discussion
    Last Post: 04-04-2009, 10:06 AM
  3. Baffled
    By Hayden in forum Audio, Security & Visual Electronics
    Last Post: 12-29-2008, 05:58 PM
  4. I truly am totally nuts.
    By Ron Vogel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-20-2008, 04:09 AM
