Thread: Engine not starting on first turn
Results 1 to 2 of 2
  1. #1 Engine not starting on first turn
    kentwood, MI
    hey everybody i have a question I can't seem to find an answer to in forums i searched. I have an 05 gt that for some reason will sporadically not start on first attempt. I hear the fuel pump kick on, the starter turns like it should motor sounds as though it wants to start but will die. Turn the key again and starts like a champ. Happens when engine is cold and after its warmed up. A few times I thought the car had started and tried to put the car in gear or in reverse and then realize the cars not running lol. Anyways I have seen some possibilities of a fuel pressure issue to cam position sensor. Just wondering if anyone else has had this issue or knows of a way to get this fixed.
  2. #2 Re: Engine not starting on first turn
    Charles City, IA
    Check fuel pressure. Probably the fuel pump. There is a check valve that is not working right and is letting the fuel run back into the tank.
    SMGPFC Two Nipple General
  1. Dont like to turn left but easy to turn right
    By Randall in forum General Tech Discussion
    Last Post: 02-01-2013, 12:11 PM
  2. General Starting and Engine Troubleshooting Guide [*]
    By TyroElite in forum How To Write-Ups/Tech Tips
    Last Post: 12-15-2010, 12:24 PM
  3. Has a really hard time starting when engine is hot
    By spenc938 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-05-2008, 11:27 PM
  4. Turn signals kill engine
    By clem in forum General Tech Discussion
    Last Post: 03-27-2008, 09:04 PM
  5. Problems Starting after Engine Replacement.
    By Metallistar in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-24-2008, 07:54 PM
