Thread: More Low/Midrange power... without doing a top swap.
Results 1 to 4 of 4
  1. #1 More Low/Midrange power... without doing a top swap.
    GTP Level Member BlownBigBlock's Avatar
    Apr 2009
    Carlisle PA
    Yes, I've read the "Safely Modding your 3800" post, figured I'd cover that before I get chastised..
    With that being said, the basic mods, IE: ported/polish TB, HV3, headers, increased rocker ratio, different intake, 180 stat, new PCM whatever else seems mostly geared towards the 5000rpm+ range but what about low to midrange improvements.
    Not looking to go the top swap route, but was just curious with the L36's if with a few mods you can improve the low to midrange.
    TIA
  2. #2 Re: More Low/Midrange power... without doing a top swap.
    Headers...on a non head/cam N/A car? Pointless. You'll lose a BUNCH of low end with headers. Keep the PLOG/DP Combo...Go with a GTP TB and GTP injectors...or a cam. Cam will help every bit of midrange and the PLOG/DP combo will keep the low end torque you lost with headers.
  3. #3 Re: More Low/Midrange power... without doing a top swap.
    Donating Users chrisb's Avatar
    Bucyrus, OH
    I ran headers on my n/a car with a cam and without, I cant say it was pointless but for the money it might be for some. I think cam would be the only way. I cant remember if retarding the cam timing gives more lowend or more top end? idk its been awhile. Oh and a tune with out tq managment with a bit more timing/compression.
    99 Grand Prix old build- CAI, Custom exhaust, HV3, Stage 2 TB, custom tune, ported heads intense s1x cam, headers.
    Nothing great Just a small T66 Turbo with a Hv3 On a stock tranny untill i finish the other one.
  4. #4 Re: More Low/Midrange power... without doing a top swap.
    if you know how to degree a cam and want to experiment by throwing money into the wind on gaskets then go for it, but im not sure that anything you put on the car is going to give you low end. pretty much everything you buy is looking to add power up top where our cars lack it.
  1. More power!?!?!?!?!?!?!
    By GINOSGTP in forum General Tech Discussion
    Last Post: 03-05-2009, 11:25 PM
  2. Need more N.A power
    By 99prixgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-21-2008, 01:32 AM
  3. tcs off = more power ??
    Last Post: 08-29-2008, 01:44 AM
  4. Need more power help!!!
    By bkaab in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-02-2008, 09:02 PM
  5. Power Cut off
    By bburrows in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-02-2008, 05:07 PM
