Thread: Runs 5 minutes...Stalls...Changed everything
Results 1 to 13 of 13
  1. #1 Re: Runs 5 minutes...Stalls...Changed everything
    Oklahoma
    What you are describing sounds like an issue with the CPS. You got the remember that the CPS is a two segment sensor. One part controls the tach signal and thus has a play in TCS, the other controls the spark. When I replaced mine last, for the second time, in January I too did not have any TCS indications or Tach indications. However, I could idle the car then after a few minutes it would just die and would not restart right away. The first time it was replaced, it would stumble a bit and I MIGHT loose the tach and TCS and it would keep on going. Occasionally it would just outright die or stall on me but it would start back up fairly quickly.
    The one way to prove it is the CPS is to let it idle until it dies. Then pull the #1 plug off at the coil pack end. Stick a screw driver up into the boot so that it make contact with the metal clip. Then with the help of a friend, spouse, etc, have them get in the car and try and start it. You'll want to hold the metal part of the screwdriver close to the coil pack terminal and see if it is getting any spark. Obviously you dont want to be touching the metal of the screwdriver with your hand unless you like that sorta thing.
    If you are not getting any spark there then I feel confident in saying the issue is likely the CPS. Ive put two of those things on my car in the past 4 years. I certainly understand your frustration, trust me I do. You've spent all this money and are no better of as a results. But do this bit of troubleshooting so that we can rule out the CPS for sure. After that, with all the work you have done, there isnt much else to check and my next step would be to look at the MAF. Because you did not mention it Im going to assume there are no codes or SES light.
    You'll have to bear with us as troubleshooting with only text is a challenge to say the least unless someone here has had the exact same problem. We dont get to hear how the car runs when it does, we dont get to hear how it dies, we cant hook a laptop up to it or a scan tool and so on. Look at it like this. You arent going to have to worry much about anything once you get it running, its all been replaced.
  2. #2 Re: Runs 5 minutes...Stalls...Changed everything
    SE Level Member TAWinner23's Avatar
    Locust Grove, GA
    Thanks for the help...I will check the CPS this weekend. It was new with the engine in Dec. but that doesn't mean very much.
    Also, I was reading somewhere about the EVAP canister. I started messing with the EVAP solenoid (purge valve), when I disconnected it the car ran ok for a couple of minutes, I unplugged it, disconnected the hoses and it didn't seem to make much of a difference. But the solenoid felt like it was turning on and off randomly (when plugged in). When I blocked the hose (the one beside the coils) it shut the car down quick. But the car would run with this entire piece unplugged and disconnected. It eventually died.
    Could this be a possible problem?
    Also, I didn't mention it earlier but there are not SES lights and I have checked every fuse possible.
    Once again thank you for the help...I'll keep it up
  1. Need some help folks, car starts, runs, then dies
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2010, 05:48 AM
  2. Car runs rich and surges at an idle?
    By Andrew_99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-13-2008, 02:54 PM
  3. Changed up the front of my '04 today
    By FastKatt in forum Visual/Body Modifications
    Last Post: 03-13-2008, 06:50 AM
