Thread: problem #2.. #5 on heat control not working
Results 1 to 7 of 7
  1. #1 Re: problem #2.. #5 on heat control not working
    Charles City, IA
    Thats normal dex cool sludge. Need to flush it out.
    SMGPFC Two Nipple General
  2. #2 Re: problem #2.. #5 on heat control not working
    PA
    First thing I would check is the fuse. IIRC #5 has a different fuse than #1-4. So check that first. Then try the blower motor resistor.
    As for the coolant. Do a flush and fill with new coolant and put in a new t-stat at the same time. Should be cheap to do.
    2001 GSE
  1. Heat Problem
    By holmz in forum General Tech Discussion
    Last Post: 12-07-2009, 08:34 PM
  2. Temp control not working. Need help!
    By rangermike in forum Audio, Security & Visual Electronics
    Last Post: 05-02-2009, 03:43 PM
  3. Heat/fans problem getting worse
    By Freebeer187 in forum General Tech Discussion
    Last Post: 01-11-2009, 06:38 PM
  4. Cabin heat question - Possible problem
    Last Post: 11-13-2008, 08:42 AM
  5. Cruise Control stopped working
    By 98gpgt98 in forum General Tech Discussion
    Last Post: 07-03-2008, 11:48 PM
