97 grand prix 3.8 l non super charged
Ok here goes, just bought the car, was told did not start replaced fuel pressure regulator and started great drove for a few weeks, now it will just crank and not start. Pulled plug wire and the screw driver test and i am getting no spark. I read many posts and saw to replace crank position sensor, wiring seems ok. Still no start just cranks, no spark seen, took out icm and took to Autozone they tested it ten or twelve times, test good. put back in no, spark, checked ground from icm which seems to be located under Icm. Had to take battery out and get it charge cause i killed it with all the starting. Took two plugs out just look a little old but no fluid on them, i am getting 50 psi of fuel, give or take a pound. this now brings me to help. anyone. help...
