Make sure your not getting any leaks between your air filter assembly and throttle body. I had a bad gasket right at the throttle body with a slight crack and caused a lot of problems, yours is very similar to one I had. As the crack got bigger the car would totally stall out when getting of the gas. Cheap easy fix?
