My job this weekend will be installing a set of ZZP ER Rockers (1.85 to 1 for the intake valve and 1.80 to 1 for the exhaust valve) on my L36 engine.
I have two new coolant elbows,new rocker bolts,and gaskets coming with the
rockers also have all the torque specs.(thanks to VinnieGTP for posting and Andrew 99 GTP for asking).I just have one question would it be less messy if I
drain like a quart of antifreeze from the radiator so the fluid is lower in the block when I remove the coolant elbows? Any other helpful input on this job would be great.
