Thread: Installing ZZP ER Rocker Arms??
Results 1 to 10 of 10
  1. #1 Installing ZZP ER Rocker Arms??
    MA
    My job this weekend will be installing a set of ZZP ER Rockers (1.85 to 1 for the intake valve and 1.80 to 1 for the exhaust valve) on my L36 engine.
    I have two new coolant elbows,new rocker bolts,and gaskets coming with the
    rockers also have all the torque specs.(thanks to VinnieGTP for posting and Andrew 99 GTP for asking).I just have one question would it be less messy if I
    drain like a quart of antifreeze from the radiator so the fluid is lower in the block when I remove the coolant elbows? Any other helpful input on this job would be great.
  2. #2 Re: Installing ZZP ER Rocker Arms??
    If your going to drain a quart...might as well just drain it all out and flush it...probably wouldn't hurt either. Especially if you have Dexcool in it...if not...just drain it out until it stops...just makes life easier and LESS messy trying to plug it back up while it is draining. You are still gonna lose some coolant that is sitting up top though...just a FYI.
  3. #3 Re: Installing ZZP ER Rocker Arms??
    Charles City, IA
    Dab a little rtv on the valve cover gaskets to help hold them in when you put the cover back on.
    SMGPFC Two Nipple General
  4. #4 Re: Installing ZZP ER Rocker Arms??
    MA
    Success!! Not to bad of a job glad i got the coolant elbows top one broke
    when I was taking the Alt. bracket off had to dig it out of the intake.Also flushed the coolant system took about 6 hours to do everything.Didn't take for ride yet it is pouring rain here hope it's sunny tomorrow.TY for
    your input.
  5. #5 Re: Installing ZZP ER Rocker Arms??
    MA
    Rotating the engine really helps
  6. #6 Re: Installing ZZP ER Rocker Arms??
    Charles City, IA
    Should have pulled all those brackets off the back. Makes plugs even easier. Other than that good job.
  7. #7 Re: Installing ZZP ER Rocker Arms??
    GT Level Member skidoojames151's Avatar
    seattle
    so how are the performance gains?
  8. #8 Re: Installing ZZP ER Rocker Arms??
    ^^Probably still raining?
  9. #9 Re: Installing ZZP ER Rocker Arms??
    Dec 2008
    Lawndale, CA
    You will like the rockers.
  10. #10 Re: Installing ZZP ER Rocker Arms??
    MA
    Seems quieter at idle? and more consistent power through-out the rpm range idle to 6000. Second gear really pulls a lot more with the stock ones it would stop pulling at
    about 4500-5000rpm.
  1. Rocker Arms
    By stlmo_gtp in forum PCM Tuning
    Last Post: 10-01-2009, 11:08 PM
  2. 1.9 Rocker arms
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-07-2009, 03:07 PM
  3. ZZP control arms
    By Sabrewings in forum Brakes/Suspension/Chassis
    Last Post: 02-20-2009, 11:06 PM
  4. BMR Adjustable Lateral arms or WBS Oversize Lateral Arms?
    By Quicklynx in forum Brakes/Suspension/Chassis
    Last Post: 11-26-2008, 02:19 PM
