Thread: first under the hood mod
Results 1 to 20 of 31
  1. #1 first under the hood mod
    mass
    what do you guys suggest dont have anythin done to it yet its an 02 gtp about 80000 miles on it
    2002 Grand Prix GTP stock for now
  2. #2 Re: first under the hood mod
    Norristown, PA
    intake, preferably a fenderwell intake
  3. #3 Re: first under the hood mod
  4. #4 Re: first under the hood mod
    Norristown, PA
  5. #5 Re: first under the hood mod
    GTX Level Member 97gtsc's Avatar
    Jul 2008
    Livonia MI.
    FWI/DP/180ts/smaller pulley/tune
  6. #6 Re: first under the hood mod
    Charles City, IA
    First mod= drink of choice and read old threads for about 2 hours. Then decide what to do, but I am with Bio save up get an intercooler. Until then slap a filter on the tb and listen to the whine. Also your GTP is not N/a.
    SMGPFC Two Nipple General
  7. #7 Re: first under the hood mod
    why all the double posts...READ READ READ should be the first brain mod
  8. #8 Re: first under the hood mod
    Joliet, IL
    best noob mod....6 pack and lots of time with the search button
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  9. #9 Re: first under the hood mod
    GT Level Member mvp2765's Avatar
    Chicago
    CAI!!
  10. #10 Re: first under the hood mod
    Wausau, WI
    Quote Originally Posted by kyle33 View Post
    what is your budget?
  11. #11 Re: first under the hood mod
    Quote Originally Posted by mvp2765 View Post
    CAI!!
    Fail.
    Why bring more air in and create a potential of knock then get rid of the air it is already bringing in faster...first. Get a downpipe or at least a u-bend delete.
  12. #12 Re: first under the hood mod
    Chicago
    ^^^^right, because that u-bend delete is so heart warming and creates the most power for a "first" mod....Most people start off with a CAI and then get 3.4 pulley right after, then mess with the exhaust and get a pcm tune along with a few small mods in between such as better belts or etc...
  13. #13 Re: first under the hood mod
    Charles City, IA
    Wow that is about the worse advice I have seen in awhile. Why not just tell him to run it low on oil to save some weight. Yeah lets see how much air we can shove in tell it blows up. No thanks. You sir should not be giving advice. You need to read the safely modding your 3800 thread. Written by the man you tried to correct. Then print it off and slap your self with it to drive the point home.
  14. #14 Re: first under the hood mod
    Yeah...I like your idea best. Maybe print it on a boulder first before he hits himself. Might work better.
    Do they do everything crazy up there in Chicago?
    You start talking about boost...you sure do know a lot. Must be really smart since your talking about pulley drops in the NATURALLY ASPIRATED SECTION.
    Idiot.
  15. #15 Re: first under the hood mod
    Charles City, IA
    The op does have a GTP tho. He messed up and put it in the wrong section
  16. #16 Re: first under the hood mod
    I know...but most people keep the boosted conversations in the SUPERCHARGED section right?
    Or am I just delusional?
  17. #17 Re: first under the hood mod
    Charles City, IA
    Nobody post where they should anymore. They just click till they can post.
  18. #18 Re: first under the hood mod
    SE Level Member beast3300's Avatar
    First performance mod is maintenance. Replace all the fluids, filters, tune up, seafoam cleaning.
    That alone will give you alot nicer car to drive, whether it's a GT or GTP or Ford Escort.
    Black 98 Regal GS: best run 13.95@99.75
    99 Red GP L36: 15.5 in 1/4
  19. #19 Re: first under the hood mod
    Charles City, IA
    Quote Originally Posted by beast3300 View Post
    That is the first thing in the safely modding your 3800 thread. It is the first thing I do as soon as I buy a car.
  20. #20 Re: first under the hood mod
    I did that on my '07 Cobalt too...plugs, air filter, oil filter, oil change...I don't care if it needed it or not...it gets done.
  1. Converting stock hood to "40th Anniversary" hood w/heat extractors[*]
    By Quicksilver_GP in forum How To Write-Ups/Tech Tips
    Last Post: 08-28-2013, 09:12 PM
