Thread: Gas Burning QUICK!
Results 1 to 20 of 33
  1. #1 Gas Burning QUICK!
    SE Level Member ThePrixGt's Avatar
    chicago, illinois
    I filled up my car on Saturday afternoon. I went to work saturday night and ive been off for the past two days. Just on routine trips back and forth my car has went through almost an entire tank of gas since saturday. Can anyone offer any insight as to how or what can be making my fuel burn so quickly.
    Thanks
  2. #2 Re: Gas Burning QUICK!
    Wausau, WI
    what mpg's are you getting? How many miles to a tank? How heavy is your right foot? Did you get crappy gas? How old are your plugs and wires? Does your car seem to be running right? DId you let it idle for long periods of times? What year make and model do you have? Any mods done to it? City driving or highway?
  3. #3 Re: Gas Burning QUICK!
    what he said ^^
    i can go through a tank of gas in like 200 miles if i am constantly in the pedal, but if i drive like a grandma i get closer to 280.
  4. #4 Re: Gas Burning QUICK!
    chicago, illinois
    When i fill up i usually get around 320 miles to a tank. I drive moderately since im usually on the street. I get Bp gas all the time and i use plus, plugs and wires were done about six months ago. It runs fine and there were no long periods of idling. No mods and mostly city driving. I just filled up again tonight before i got to work and it should last until about this time next week. I'll have to wait a day or so and see how it goes this time.
  5. #5 Re: Gas Burning QUICK!
    Wausau, WI
    If you are getting 320 miles to a tank, that is actually pretty good for mostly city driving........I can get that on the highway, but not in the city. That should equate to somewhere in the neighborhood of 25MPG........do you consider that bad for mostly city driving?
  6. #6 Re: Gas Burning QUICK!
    hell, i cant even get that on the highway. if i get 300 miles of straight highway driving in a tank then im happy as a pig in ****.
  7. #7 Re: Gas Burning QUICK!
    Wausau, WI
    yeah..........but you need to get that driver delete mod to improve your MPG's.....
  8. #8 Re: Gas Burning QUICK!
  9. #9 Re: Gas Burning QUICK!
    SE Level Member KlutchKrunch's Avatar
    Canada
    Another contributing factor can be your injectors, run a Fuel Injector cleaner, such as Lucas, it'll help not only clean out those dirty injectors, but as well keep them lubricated. Which will help move gas a heck of a lot better through your car.
    Just remember dude, at the end of the day, your driving a 3.8L Buick engine, not some 2.2L four cylinder.
  10. #10 Re: Gas Burning QUICK!
    riverside
    gas burning Quick!
    what is this?
  11. #11 Re: Gas Burning QUICK!
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    Im lucky if i get 220 miles to a tank :-/
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  12. #12 Re: Gas Burning QUICK!
    Dec 2008
    Lawndale, CA
    I get around 200 on a full tank with a combination of highway and street.
  13. #13 Re: Gas Burning QUICK!
    SE Level Member Jcal1120's Avatar
    Watertown, MN
    I hit around 280-320 depending on street/highway and how hard I drive my car.
  14. #14 Re: Gas Burning QUICK!
    Wausau, WI
    I was just on the freeway yesterday and according to my DIC I got 30.3 MPG's with the cruise set at 73 fwiw........I was very happy with this.
  15. #15 Re: Gas Burning QUICK!
    Alabama
    all of your miles per tank seem low. i can get 450 miles to a tank all city driving in my 06 NA 3800
  16. #16 Re: Gas Burning QUICK!
    GT Level Member skidoojames151's Avatar
    seattle
    most of the posts were ppl w modded S/C set ups with heavy foots....the numbers are about right for that..
  17. #17 Re: Gas Burning QUICK!
    Alabama
    makes sense now. because i was like thats crazy no way i could get just 200 miles out of my tank.
  18. #18 Re: Gas Burning QUICK!
    Wausau, WI
    are the gas tanks any bigger on the 04 and up's? If not I dont see how you can get thirty something MPG's in the city with a grand prix....How many gallons do you use at a fill up? Even on a stock NA 3800 you should not be getting anywhere near that much even if you drive like my grandma..........especially in the city.
  19. #19 Re: Gas Burning QUICK!
    GT Level Member BoostedComp's Avatar
    Youngstown
    my 04 comp g gets about 19 in the city... and only 25 on the highway with cruise on... and its either a 17 or 18 gallon tank.. i cant remember off the top of my head but i know its one of the two
  20. #20 Re: Gas Burning QUICK!
    Wausau, WI
    Quote Originally Posted by noom14921992 View Post
    you have a bigger gas tank also.....
  1. Burning oil, misfire #2
    By Blackbeauty01 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-05-2009, 03:43 PM
  2. burning smell
    By uNda6gT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-06-2009, 09:42 AM
  3. Burning Oil Smell
    By Bruty74 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-22-2008, 01:07 PM
  4. Engine Tuneup - Burning off carbon
    By 04CompG in forum General Tech Discussion
    Last Post: 10-30-2008, 08:38 PM
  5. Thats it, Im burning the ***** down
    By Toofastgs in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-11-2008, 08:52 AM
