Hey guys.. I've read a lot on here trying to see if anyone has the same trouble that I've had over the last few days.. I think I know what it is but figured I'd ask..
2002 GP GT 3.8 car has zero power right now.. no codes flashing
While at idle
she idles perfect, give it more than 2000 RPM and it'll start bogging bag and start running very lean.. sounds like it's almost starving for fuel or it can't exhale..
While driving.. zero power at all.. if I give it more than the 2000 RPM mark, it actually revs up but starts bogging bad and will not go past 4000 RPM, no bucking, and looses power and speed bad... It takes me about 1-2 miles to get up to highway speed and it's impossible to stay there when I come to a hill..
So far I replaced the MAF and MAP.. no change..
Checked air filter..clean.. actually pulled it off and no change either
Changed fuel filter.. lots of flow and pressure
I'm puzzled...
I'm thinking after reading other posts on here that it might be a plugged Catalytic Con. or a vaccuum leak..
What do you guys think
Rob
