Thread: Troubleshooting: car won't start
Results 1 to 14 of 14
  1. #1 Re: Troubleshooting: car won't start
    Wausau, WI
    MAF, IAC, Fuel pump, Fuel pump relay, ICM, etc..............codes would help if you have any. LIM gasket/head gasket could be going if you are seeing white smoke out of your exhaust. Does your coolant and oil look normal and are they both up to normal levels?
  2. #2 Re: Troubleshooting: car won't start
    Raleigh,NC
    All the fluid levels are normal, There is no check engine light on. When i start the car i don't notice any white smoke.
  3. #3 Re: Troubleshooting: car won't start
    Raleigh,NC
    Well today i decided to figure out what is wrong with this car, The car started right up just fine, idled great like it should. Drove the car for about 10 minutes and it started to run rough, Rpm's up and down, pulled into neighborhood and the car just shut off. I got the car restarted as i was pulling into driveway i noticed black smoke coming from exhaust and smelt like fireworks. I was doing some reading on here and read somewhere to check the spark on the plugs to determine if ICM is working correctly, The plugs have spark. So now i don't know where else to look. The car starts to run like crap when it's hot, so i was thinking ICM
  1. Troubleshooting help. Engine won"t start
    By jimcarey78 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-13-2011, 06:58 AM
  2. Troubleshooting Help! 02 GTP - DIC/ AC Issue
    By Lawngoose in forum General Tech Discussion
    Last Post: 07-21-2010, 12:28 PM
  3. DIC troubleshooting
    By skidoojames151 in forum General Tech Discussion
    Last Post: 05-15-2010, 09:39 PM
  4. Need Help On Troubleshooting Bulldog Security Remote Start Install
    By eb97951 in forum General Tech Discussion
    Last Post: 12-24-2008, 07:39 AM
  5. Troubleshooting Help! - A/C Problems
    By kappy332 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-21-2008, 04:07 PM
