Thread: Accleration mods..
Page 1 of 3 123 LastLast
Results 1 to 20 of 58
  1. #1 Accleration mods..
    SE Level Member 08GrandPrixV6's Avatar
    South Dakota
    I LOVE my new 08 Grand Prix V6 and I thinks its quick but wouldn't mind a little faster acceleration so I bought a K&N drop in filter.
    So I finally got around to buying a K&N drop in air filter and I can tell a small difference in acceleration. It's not a HUGE difference but definitely worth $40.
    The point in this thread is to ask you guys if there are any other Cheap, easy to install mods for my car that will help with acceleration? (I don't care about top end speed)
    Thanks a bunch!
  2. #2 Re: Accleration mods..
    Wausau, WI
    read the safely modding your 3800 thread in the general tech section...it has tons of info. You could make your own fenderwell intake for about the same price as you just bought your filter for........good luck with the mods... downpipe....plog...tune is a huge one.... HV3...and of course the FWI
  3. #3 Re: Accleration mods..
    that drop in K&N didnt give you a power boost. you got maybe 1 whp out of that.
  4. #4 Re: Accleration mods..
    South Dakota
    Ok maybe I didnt get a big HP gain but I accelerate faster and my car is a little more responsive while I drive.
  5. #5 Re: Accleration mods..
    GTX Level Member nicksilvergt99's Avatar
    Reading, PA
    Get a tuned PCM or have a local guy tune it. Most people say there is a huge difference. It's like a hundred bucks on zzp plus core charge, only downside is if your not already running premium fuel you'd have to start
    "This shocker crap is for high school kids, it's all about the double gauntlets, that's right, 2 fists forearm deep, someone make me a sticker. double gauntlets > shocker"
  6. #6 Re: Accleration mods..
    Reading, PA
    Oh but don't get one from zzp haha I just know theirs is 100 dollars. 3800 performance is where you should get one if you want mail order
  7. #7 Re: Accleration mods..
    Jersey
    Quote Originally Posted by 08GrandPrixV6 View Post
    So I finally got around to buying a K&N drop in air filter and I can't tell aNY difference in acceleration. It's A POS definitely NOT worth $40.
    Thanks a bunch!
    fixed
    You wasted your money, have fun buying a new MAF sensor 1-6 months from now.
    Return that ****ty drop in and make yourself a proper intake.
    16' wrx sti- stock
  8. #8 Re: Accleration mods..
    READ STICKY THREADS!!! Safely Modding your 3800 in the general tech section.
  9. #9 Re: Accleration mods..
    Wausau, WI
    I already recommended it.....go take your pills..........settle down......LOL
  10. #10 Re: Accleration mods..
    South Dakota
    Quote Originally Posted by 99prixgt View Post
    fixed
    If I knew how I would and Im afraid I would wreck my engine..
  11. #11 Re: Accleration mods..
    Wausau, WI
    now you do............http://www.grandprixforums.net/f73/m...ke-fwi-20.html
    you will not ruin anything in your motor unless you are completely careless. You would almost have to try to ruin it.........this is very easy.......keep your eyes open and when you are all done just make sure to vacuum in any area that may be open to your motor if there are any, or you could also use an air hose depending on the application...you will be fine. If you do not want to make it yourself, just buy one that you can install.....TDC racing makes a good one that is priced very fairly and cheaper than most.......check out his website. He is a vendor on this site.
  12. #12 Re: Accleration mods..
    SE Level Member tihosick's Avatar
    meadville, Pa
    i have a 01 gt. and it has a drop in k&n...and my maf sensor is bad is this why?
  13. #13 Re: Accleration mods..
    Norristown, PA
    i have an k&n drop in, should i get rid of it? how hard is it to remove the intake box?
  14. #14 Re: Accleration mods..
    South Dakota
    Quote Originally Posted by Liquifire View Post
    I could "probably" do something similar to this:
    [IMG]file:///C:/DOCUME%7E1/Owner/LOCALS%7E1/Temp/moz-screenshot.png[/IMG]
    but I could not make a FWI. Would the picture above be just as effective? And How much HP would I look at gaining?
    Thanks
  15. #15 Re: Accleration mods..
    meadville, Pa
    why wouldnt you be able to make a FWI? i dont know just loos easy? by doing that i wouldnt think u could gain to much....u would be getting all the hot air under the hood
  16. #16 Re: Accleration mods..
    SE Level Member Everblades2's Avatar
    Florida
    Build the FWI. It was my first ever car project and mine is fine. Just make sure the cone fits. It's fairly easy to build yourself.
    2008 Grand Prix Base - HV3, ZZP Downpipe, Custom FWI, Dual Exhaust (Magnaflows / Magnaflow Hi-Flow Cat), 15%/25% Tint
  17. #17 Re: Accleration mods..
    meadville, Pa
    yeah it looks it............and youll be beter off
  18. #18 Re: Accleration mods..
    South Dakota
    Quote Originally Posted by Everblades2 View Post
    I would like too but in the guide on how to build and install one it says you have to cut your roof flashing, take off the bumper or headlight and I have no idea how to do either nor do I want to.
  19. #19 Re: Accleration mods..
    Florida
    Okay, I never had to take off the bumper or the headlight. The only thing I undid was that metal piece that goes over the air box. And when you buy the roof flashing you just cut it little by little until it fits good. If you mess up they are only like 6 bucks.
  20. #20 Re: Accleration mods..
    South Dakota
    Oh alright. So I see that you have a base grand prix. So my quesion is how much of a difference did you notice ,or hp gain, while driing after you put your custom fwi in?
  1. mods to come!
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-08-2009, 03:38 PM
  2. Next Mods
    By Clar2478 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-03-2009, 02:11 AM
  3. New mods
    By Js97GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-29-2008, 04:52 PM
  4. New mods
    By Js97GTP in forum General Tech Discussion
    Last Post: 11-23-2008, 09:47 PM
  5. I need some help with mods
    By GTPRiley in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-17-2008, 12:03 PM
