Thread: GTP DIC work with 2000 gt?
Results 1 to 11 of 11
  1. #1 GTP DIC work with 2000 gt?
    GT Level Member bballa0740's Avatar
    Apr 2009
    br
    will the gtp dic work with my gt? like after i do top swap
  2. #2 Re: GTP DIC work with 2000 gt?
    Apr 2009
    br
    or even befor?
    E85, Gen V, TOG Headers, 2.55 w/ SFI balancer, 3PE, Tranny, NIC Cam, 1.7 Yella Terra Rockers, LS6 springs, ...goood day sirrr ryan carter tuning
  3. #3 Re: GTP DIC work with 2000 gt?
    Wausau, WI
    The digital display DIC?
  4. #4 Re: GTP DIC work with 2000 gt?
    I'm thinking he means the digital DIC. I thought the plugs or wiring was different. I could be wrong though.
  5. #5 Re: GTP DIC work with 2000 gt?
    Apr 2009
    br
    2000 Grand Prix GTP DIC Digital Information 09360352:eBay Motors (item 390084036326 end time Sep-18-09 21:05:17 PDT)
    will that work on my gt it says it wont but i thought you could wire it to work jus wonderin?
  6. #6 Re: GTP DIC work with 2000 gt?
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  7. #7 Re: GTP DIC work with 2000 gt?
    Apr 2009
    br
  8. #8 Re: GTP DIC work with 2000 gt?
    Nov 2008
    Fremont Nebraska
    again, yes.
  9. #9 Re: GTP DIC work with 2000 gt?
    Apr 2009
    br
    you have one in gt and is it hard to wire or pretty simple?
  10. #10 Re: GTP DIC work with 2000 gt?
    Nov 2008
    Fremont Nebraska
    i have not personally done it. from reading thorugh that thread and asking the questions i asked, in my opinion, it doesnt sound very hard. Ive made the decision to invest 100% of my "car" money into making my car faster. since this wont make my car faster, im not gonna do it.
  11. #11 Re: GTP DIC work with 2000 gt?
    GTP Level Member SuperSport's Avatar
    Michigan
    I just installed a Digital DIC in my GT last week. I ordered it from Morad Parts. It took a few hours of wiring but it was pretty simple. You need to splice into the VSS wire from the back of the speedo, the DLC wire at the diagnostics port, and you need a constant and lighting wire spliced from the back of the radio, along with matching the corresponding wires from the basic DIC.
    Easy but tedious swap. I followed this thread as well. 1997-2003 Grand Prix Analog to Digital DIC Conversion - Automotive Forums .com Car Chat
    Also, if you have a GT, you need the unit with the "TRAC" button and not the "TCS" button. In other words only a GT DIC will work with a GT. Mine has the TRAC button, and at an angle, you can see the boost gauge so somehow that may work after the top swap, but havent looked into that.
    Make sure when you order from ebay, order from Morad to ensure you get the plug and a few inches of wire with it sore youre able to splice.
    Good Luck.
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  1. will these rims work on a 2000 gt?
    By stanggreg90 in forum Tires & Wheels
    Last Post: 09-15-2009, 03:02 PM
  2. Key from dealer doesn't work - 2000 Grand Prix
    By workcar in forum General Tech Discussion
    Last Post: 09-09-2009, 07:34 PM
  3. Will a 99 N/A gp maf work ok 98 GTP
    By pontiacGTP123 in forum General Tech Discussion
    Last Post: 05-07-2009, 12:00 PM
  4. Will this work??????
    By 05grndprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-26-2008, 08:40 AM
