Thread: Top Swap/SSM90
Results 1 to 13 of 13
  1. #1 Top Swap/SSM90
    GT Level Member 01gtspecial's Avatar
    Apr 2009
    Georgia
    I want a supercharger, so I just bought a gen 3 M90, L67 LIM, L67 fuel rails/injectors, L67 heads, L67 exhaust manifolds. But now I'm not sure if I want to get into the whole top swap, do people normally have good luck with the SSM90 kit from ZZP? If so is there an alternative to their $450 fuel rail, can I make the L67 or L36 one work? I'm trying to decide what's going to be the cheapest way to get the blower on my car...
    If I continue with the top-swap then the heads I bought need to be magnafluxed and checked for cracks etc. (BTW: does anyone know how much it would cost to get a set of heads re-worked?) I would have to pay to have the S/C and LIM P&P, plus pick up the rest of the necessary parts.
    Would the SSM90 be cheaper? considering I could use the LIM and S/C I have as core's for the ported ones from the kit. Plus it's supposed to be easier to install.
    Any ideas or suggestions?
    01 GT special ed.: SD hood, GMPP kit, poly sway bushings, Eibachs/Gabriel Ultras, Eagle GTs, ZZP anti-pogo, ZZP short dogbones, ZZP poly trans, ZZP PCM, ZZP HV TB, ZZP HV3, P&P LIM, 4" FWI, 3" DP, custom exhaust, pwdr-coated Trans Am brakes, NGK iridiums, Mobil1 Syn fluids, stage 2 voltage booster, BIG 3, real loud stereo...
  2. #2 Re: Top Swap/SSM90
    GT Level Member skidoojames151's Avatar
    seattle
    well since you already have most of the parts that arent used in the SSm90 setup u might as well do a normal swap...and i personally wouldnt like my S/C run off my accesory belt
  3. #3 Re: Top Swap/SSM90
    Barksdale AFB, LA
    I paid $180 to have my heads dipped, rebuilt, cleaned, 3-angle valve job, valves resurfaed, fluxed for cracks, and milled to ensure flatness. They looked brand new when I got them back. Just to flux them if you went that way wouldn't be too expenive I'm sure.
    2009 Subaru Impreza WRX STI
  4. #4 Re: Top Swap/SSM90
    GTX Level Member nicksilvergt99's Avatar
    Reading, PA
    Subscribed
    "This shocker crap is for high school kids, it's all about the double gauntlets, that's right, 2 fists forearm deep, someone make me a sticker. double gauntlets > shocker"
  5. #5 Re: Top Swap/SSM90
    Jersey
    1 belt is just plain silly imo
    Imo do the entire top-swap, if you continue to mod your car it will make things easier in the long run.
    16' wrx sti- stock
  6. #6 Re: Top Swap/SSM90
    Oct 2008
    Northern Illinois
    You're supposed to have work done to the heads before you put them on?
  7. #7 Re: Top Swap/SSM90
    Jersey
    Quote Originally Posted by BwolfGT View Post
    Its optional but, to have them re-done would just further protect your investment imo. I paid about $190 to get mine rebuilt from a race shop. They knew exactly what motor it was from. He asked me, "Buick? 3800?" I knew I took them to the right place. They did an awesome job.
    16' wrx sti- stock
  8. #8 Re: Top Swap/SSM90
    Barksdale AFB, LA
    It would be wise. You don't want to put it all together to find out they're warped or be stuck with the fact that they're dirty from the previous owner. Get them cleaned up. Very worth it.
    Here's what my heads looked like before and after:
    http://www.grandprixforums.net/f18/r...ads-10753.html
    Quote Originally Posted by 99prixgt View Post
    Pretty much the same thing that happened with me.
  9. #9 Re: Top Swap/SSM90
    Jersey
    Quote Originally Posted by Sabrewings View Post
    ^good thread
    16' wrx sti- stock
  10. #10 Re: Top Swap/SSM90
    Oct 2008
    Northern Illinois
    Wow yeah I guess I should probably get that done...damn it...more money...
  11. #11 Re: Top Swap/SSM90
    Wausau, WI
    think long term benefits.............
  12. #12 Re: Top Swap/SSM90
    Apr 2009
    Georgia
    so i was on ZZP's website and found this head gasket set that's 190 bucks but offers ~9hp gain by increasing cylinder volume. Has anyone used these with success? would it be worth getting this over the normal Felpro gasket?
    https://www.zzperformance.com/grand_...=102&catid=103
  13. #13 Re: Top Swap/SSM90
    if youve never done engine work you dont want to try and seal those MLS gaskets. they are going to be a super pain in the ass.
  1. Top Swap vs SSm90
    By uNda6gT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-14-2009, 07:06 PM
