Thread: MSD Ignition Coils
Results 1 to 15 of 15
  1. #1 MSD Ignition Coils
    GT Level Member GP2003GT's Avatar
    Fayetteville, NY
    is there really a different between the stock coils and the MSDs? i have heard two stories...
    http://www.cardomain.com/ride/2556536 NKG Iridium Plugs, 8mm Spiro Wires, ZZP Reprogrammed PCM, ZZP 3" full cat, ZZP Ceramic Coated Ported Manifolds, ZZP HV3, ZZP HVTB, ZZP ER Ratio Rocker Arms, ZZP Drilled 180* Thermostat, MotorSports Performance Intake, Reptile's IAT and dezldave tuned
  2. #2 Re: MSD Ignition Coils
    GTP Level Member David99GTP's Avatar
    Florida
    There was a pretty heated thread over this on CGP a while back. A lot of people were bashing the MSD coils. People didnt back their claims of them being crappy with any kind of tech support. One guy finally added in the main reason people have issues is improper grounding. He claimed to run them on all of his racing vehicles and dirt vehicles with no issues. He had a buddy who said his crapped out. He said it was a ground issue and when he fixed that his buddy had no problems.
    Anyway, I am a bit off on a tangent, I have had mine going on 2 years without a single issue. I dont know about any performance gains. I first did it for dress up under the hood. I think I noticed a little better throttle responce. Seemed a bit crisper. But thats just opinion, I have no factual proof. Hopefully someone adds to this because I was curious myself what exactly the gains if any were claimed to be.
    1999 GTP
    2002 Chevy 2500HD lifted on 36" Swampers
    http://www.cardomain.com/ride/2619487
  3. #3 Re: MSD Ignition Coils
    Saraland Alabama
    the coils are not the same as the ignitions (the ignition boxes need the ground the coils plug in) I have an msd coil on my bravada, and it has been replaced under warranty 3 times, msd finally admitted they do not make the coils, they are made by someone else that also makes aftermarket replacements (probably gp sorenson or borg warner as they are the 2 big companies) they did not machine the electrical connections correctly, and the wires will pull out after a while, as far as helping, unless you are at the edge of your coil I doubt you'll see much if any improvement (less than 5 hp would be my guess which is the variance of most dynos)
  4. #4 Re: MSD Ignition Coils
    Fayetteville, NY
    yeah see thats what i want to find out...if MSD are really just for looks or is there really a noticeable performance increase...? anyone?
  5. #5 Re: MSD Ignition Coils
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    Umm I lost damn near 10hp on the dyno.
    Ran the car, had a set of msd in the trunk. Took all of 5 min to swap out ran the car lost 9hp. Swapped back out for stock dynoed again and gained 7hp over the pass with the msd.
    Waist of money
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  6. #6 Re: MSD Ignition Coils
    Fayetteville, NY
    ok so based on an actual test you lost power...i think ill just dress my stocks up real nice then if this is the case...
  7. #7 Re: MSD Ignition Coils
    Tulsa, Ok
    i would not wast the money on it.
    Only value they had is look good with a nice modded engine.
    People really under estimate gms stock ignition.
    98' GS - Sold
  8. #8 Re: MSD Ignition Coils
    Florida
    Quote Originally Posted by Toofastgs View Post
    Ive heard others say that about the stock ignition. I saved mine just in case
    1999 GTP
  9. #9 Re: MSD Ignition Coils
    Fayetteville, NY
    ok im just gonna dress up my stocks then..
  10. #10 Re: MSD Ignition Coils
    GT Level Member TurboKent's Avatar
    Woodward, OK
    My brother has been going to school up at wyotech and he's talked to me about getting mine changed. He compared the actual performance ratings on them and said that the msd coils where much much better for the simple fact of the lower resistance on them. He said with the lower resistance it generates a better/larger spark and that when i did change them i could increase the gap in my plugs to get best performance gain out of them.
  11. #11 Re: MSD Ignition Coils
    Fayetteville, NY
    hmm...some other guy talked about how he lost hp putting MSDs in and he dynoed it...so now he has his stocks back in...also another quick question have any of you painted your stock coils or know someone who has...what kind of paint did you use?..curious..
  12. #12 Re: MSD Ignition Coils
    Saraland Alabama
    they are just plastic so any plastic paint should be fine, they don't get that hot (someone recently did paint theres on here though)
  13. #13 Re: MSD Ignition Coils
    I live here. UR LOSN's Avatar
    Rockford, IL
    I have heard mixed reviews of them as well. to me it is a personal preference. I look at what the drag cars have. if it works for them....there must be a reason behind it.
    but it is up to you.....not us.
  14. #14 Re: MSD Ignition Coils
    Bastard Reptile's Avatar
    Kansas City, MO
    Mine do me just fine. I've got no complaints about them.
  15. #15 Re: MSD Ignition Coils
    Fayetteville, NY
    well i know its up to me, but i just wanted to see what other people had to say...you know?
  1. I painted my coils and fuse box cover
    By Preotic in forum Visual/Body Modifications
    Last Post: 02-22-2010, 01:13 PM
  2. Ignition Problem.
    By dbean in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-06-2008, 07:49 PM
  3. Key stuck in ignition-
    By checkm8gtp in forum General Tech Discussion
    Last Post: 02-21-2008, 07:46 PM
  4. Need More Help, Ignition
    By SyntheticShield in forum General Tech Discussion
    Last Post: 01-28-2008, 12:17 AM
