Thread: 3800 misfire HELP???
Results 1 to 5 of 5
  1. #1 3800 misfire HELP???
    Eveleth MN
    I bought a 1997 Grand Prx gt and it blew up the next day. I put a new engine in it and now there is a problem. It runs like a champ when it is cold. It pulls hard and everything but then when it warms up it misfires and chuggs like crazy when its under load. It is reading out 2 codes. One is misfire in one or more cylinders and the other is a bad o2 sensor. The sensor was bad when my old engine was in and that one ran fine. Please help. I hope its something easy. Also my gas guage is screwing up. I dont know if that is due to the problem or not.
  2. #2 Re: 3800 misfire HELP???
    Wausau, WI
    which o2 sensor? the front one is far more crucial.........if that one is bad, replace it ASAP. I believe the gas gauge info is being sent from the gas tank sending unit IIRC?
  3. #3 Re: 3800 misfire HELP???
    Eveleth MN
    It is the o2 sensor on the manifold. I also have one more question. When I was hooking up the main harness to the tranny there was i think 3 plugs. 2 of them were big and hooked up into the solenoids on the tranny but the last one is small and I dont know what it is or where it goes. Any ideas?
  4. #4 Re: 3800 misfire HELP???
    Wausau, WI
    if your front o2 sensor is not working correctly, it is critical that you replace this ASAP......not sure on the wiring issue...can you get a pic of the wiring harness that you are referring to? it would help a lot.
  5. #5 Re: 3800 misfire HELP???
    Replace the sensor...get new plugs/wires and check the coil packs/ICM.
  1. 3800 vs 3800 Supercharged
    By extreme in forum General Tech Discussion
    Last Post: 07-31-2009, 10:45 PM
  2. Misfire
    By munkee in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-12-2009, 06:46 PM
  3. #5 Misfire
    By jjbskisail in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-06-2009, 02:36 PM
  4. misfire bad
    By YoungGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-11-2008, 04:39 PM
  5. Misfire like no other
    By MTXGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2008, 10:02 AM
