Thread: misfire bad
Results 1 to 11 of 11
  1. #1 misfire bad
    GT Level Member YoungGTP's Avatar
    Aug 2008
    Iowa
    okay i leeked some coolant into the airfuel mixture due to a ripped tb gasket and i turned it over and white smoke pored out of the exhaust, i install a new rubber gasket, reved up for a bit and got the smoke to go away. it idles at about 900 now (used to be about 600) and it sounds like i have a xp cam under the hood. do i just need a tune now or what?
    -98 GTP Thunderstorm
    Cai, 3.5 press on pulley, NGK TR6's, 3" to 2.5" exhaust, thrush glasspacks, drilled 180 t-stat soon-overkill pcm, fully ported sc, N* TB, and LQ4 MAF, Future- Full I/C, XP cam, s&s headers
  2. #2 Re: misfire bad
    Barksdale AFB, LA
    Coolant could've fouled a plug.
    2009 Subaru Impreza WRX STI
  3. #3 Re: misfire bad
    Aug 2008
    Iowa
    so just replace all the plugs and see what happens? it is okay to drive as of now or do i need it to sit till then?
  4. #4 Re: misfire bad
    Barksdale AFB, LA
    Is it actually misfiring or just running rough?
  5. #5 Re: misfire bad
    Aug 2008
    Iowa
    im gonna have to go with rough. my description of it sounding like its camed is as close as i can get. very very lumpy for no cam
  6. #6 Re: misfire bad
    Aug 2008
    Iowa
    anyone else?
  7. #7 Re: misfire bad
    Barksdale AFB, LA
    If it was misfiring, you'd get a CEL and a DTC for a misfire. Take it for a drive. Don't romp on it, just give it a chance to clear its system completely. Let it heat up to operating temp to fully burn out anything left behind.
  8. #8 Re: misfire bad
    Aug 2008
    Iowa
    alright ill do that in the morning going to school and top off the coolant. i let ya know if its still acting up tomorro night, one quick question for ya though. im gettin a fully ported sc, N* Tb, and the LQ4 maf. would that do okay with a plog (i will only be running a 4.2 pulley for gas milage for now)
  9. #9 Re: misfire bad
    Bastard Reptile's Avatar
    Kansas City, MO
    If the drive doesn't fix it, pull the plugs and inspect them. Might clean them up a little also. Coolant can really bug up a plug and you just have to use a cigarette lighter to heat them up and evaporate the coolant. sucks
  10. #10 Re: misfire bad
    Aug 2008
    Iowa
    i remembered the guy before me zip tied the vacum hose i looked back and sure enough there was a big rip (old) so i got new hose and fixed it. runs as good as new. thanks for the help though guys
  11. #11 Re: misfire bad
    Barksdale AFB, LA
    Plog should do fine with those mods.
  1. dtc p1380 misfire
    By badprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-25-2008, 09:03 AM
  2. trouble starting, misfire
    By Toasty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-16-2008, 11:55 PM
  3. Engine misfire HELP!!
    By TDCRacing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2008, 10:16 AM
  4. #4 cylinder misfire
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2008, 06:16 PM
  5. Misfire like no other
    By MTXGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2008, 10:02 AM
