Thread: 97 gt na to super swap
Results 1 to 11 of 11
  1. #1 97 gt na to super swap
    SE Level Member eddie97gt's Avatar
    Feb 2009
    roanoke va
    my na gt just turned 200,000 miles , and im toying with the idea of getting a junkyard 3.8 supercharged and gonna do a rebuild on it and wondering what its gonna take to put it in , is it pcm and a little wiring (for whitch im not afraid at all to do ) . im probably go a little nuts with this id like to pull 8's in the eighth so im thinking doing the hd tranny wouldent be a bad idea so any info would be much appreciated .
    p.s. if i have the motor ready to go can it be done in a weekend?
  2. #2 Re: 97 gt na to super swap
    too bad you have the crappy transmission to work with. you should switch the electronic transmission in at the same time or youre going to have problems tuning the shifts and what not.
    otherwise if youve got everything ready to go it wouldnt be hard to swap everything over in a weekend.
  3. #3 Re: 97 gt na to super swap
    8's in the 1/8?
    That's not hard that's like mid to high 13's.
  4. #4 Re: 97 gt na to super swap
    Wausau, WI
    that would be hard on his 97 GT tranny with 200k on it........I would upgrade the trans as well before you do this......
  5. #5 Re: 97 gt na to super swap
    Quote Originally Posted by Liquifire View Post
    I was talking about with a GTP trans. and motor.
  6. #6 Re: 97 gt na to super swap
    Wausau, WI
    I meant hard on the equipment, not hard to accomplish........
  7. #7 Re: 97 gt na to super swap
    Well considering we told him to swap transmissions too...it shouldn't be a issue.
  8. #8 Re: 97 gt na to super swap
    Feb 2009
    roanoke va
    well i had the transmission swapped about 2 years ago , blew out on my way to bristol in abingdon va ... funny story about that too ... but ill save that for another time ... but its the same 4t60e , think i got that right , but its shifting hard from first to second , and the torque converter takes forever to lock up , now what hd transmission can i put in without changing ecu and harness ..... kinda on a budget here ive got a spare ecu and a friend of mine can do the flash for me at the gm dealership , ive got about 1000 bucks to do this and the motor with 82,000 miles complete for 560 so i cant express on a budget enough ... thanks for all the help so far fellas ... and any meetings near va anytime soon , love to see some of the cars at the strip or roadcourse
  9. #9 Re: 97 gt na to super swap
    just get a whole 98+ setup. it will be your best bet. the vacuum controlled tranny is straight junk
  10. #10 Re: 97 gt na to super swap
    Feb 2009
    roanoke va
    so the best bet is to swap the harness and everything? i assuming you have to do that with the electronic tranny ?
  11. #11 Re: 97 gt na to super swap
  1. super mod that i have not seen anyone do yet
    By Toasty in forum General Tech Discussion
    Last Post: 10-14-2009, 07:41 PM
  2. super charger
    By 00pontiac1971 in forum General Tech Discussion
    Last Post: 05-12-2009, 02:12 AM
  3. VW TDI super cup
    By UR LOSN in forum Off Topic Discussion
    Last Post: 11-19-2008, 02:46 PM
  4. Super charged/non-super charged question
    By ohgreatone32 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-04-2008, 10:31 PM
