Thread: Cooling fans only work with ac
Results 1 to 5 of 5
  1. #1 Cooling fans only work with ac
    SE Level Member Skeeve's Avatar
    carneyville FL
    My cooling fans only kick on when i turn the ac on, the car has been overheating lately and ive noticed the fans dont kick on at all.
    whats my problem? well... the cars problem anyway LOL
  2. #2 Re: Cooling fans only work with ac
    Wausau, WI
    the temp sensor? it could be reading cooler than what the actual temps are and therefore not telling the fans to turn on. I am not sure if that has seperate relay to turn on fans other than the AC........I guess you have to turn on your ac pump if the motor temps are getting up there at least until you get this figured out. Not sure which fuses and relays they are off hand..........hopefully someone chimes in who knows which numbers they are for sure........
  3. #3 Re: Cooling fans only work with ac
    carneyville FL
    Definately not the Coolant sensor, replaced it this morning, old one was reporting 30 degree variance, engine was hotter than it said it was.
  4. #4 Re: Cooling fans only work with ac
    Feb 2008
    West Jordan, UT
    I've had this same problem for a year and a half. I've spent hours online and even on the phone discussing it with forums members.
    So far, no solution.
  5. #5 Re: Cooling fans only work with ac
    Wausau, WI
    as a last resort, you could always get aftermarket equipment and have them operate independantly.........
  1. 99 cooling fan issue
    By spidyrmen in forum General Tech Discussion
    Last Post: 04-23-2013, 05:04 PM
  2. coolant fans only work when A/C is on
    By bigwillie in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-26-2011, 07:14 PM
  3. Cooling fans always on?
    By oldschoolpontiacs in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-14-2009, 01:29 AM
  4. Cooling
    By Davisgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-10-2009, 07:30 PM
  5. Cooling fan swtich
    By bkaab in forum General Tech Discussion
    Last Post: 04-11-2008, 10:54 PM
