Thread: Exhaust Advice
Page 1 of 3 123 LastLast
Results 1 to 20 of 45
  1. #1 Exhaust Advice
    Grand Island, Nebraska
    I have an '01 Grand prix GT and my only mod is a FWI. Im considering doing a top swap in the future but i've decided to upgrade my exhaust first. i want to keep my cat back because its a lot of money for something that doesnt increase performance at my level and i dont want it to sound like it has balls since it doesnt. i also want a cat because i dont want to get in trouble for it and im kinda green. And no res delete because i hear it sounds like crap. for my so far low HP motor would a front manifold and downpipe be sufficient, or should i just get the headers with the DP? i also would like to know the sound difference (if any) between the two. about 900 is what im willing to spend, but it will take me a while to get the money and im willing to save. also would i need a tune with any of these? i hope i was specific enough.
    front manifold is $270 from ZZP + $250 ZZP 3" DP ($50 cat return) =$470
    $900 stainless steel ZZP headers with 3" DP ($50 cat return)= $850
    P.S. ive seen a video on youtube of a grand prix with exhaust that sounded like cowbells. it was hilarious but i cant find it again, anyone have a link?
  2. #2 Re: Exhaust Advice
    if you can afford the headers then go for those if youre wanting to top swap later on. i wouldnt buy the ZZP headers though. they are overpriced for what they are.
  3. #3 Re: Exhaust Advice
    Wausau, WI
    well........you wouldnt need the headers until after you do a top swap with higher HP than a 3.4 so the bigger question is-how far do you plan on going? The headers obviously work better overall, but would be overkill for a while on what you need. I thought the front PLOG was cheaper than $270.......maybe 270 for both(which is not needed)
  4. #4 Re: Exhaust Advice
    well its $80 for the ceramic coating on the plog (was wondering if this is worth it?). i was also thinking the headers were overkill like liquifire said. i heard the plog and dp are good for a 3.4 setup which i dont even know if ill be able to get to. so i think ill go with the DP and use the $50 cat return to help pay for the plog.
    how will this affect sound? i would like a better tone but i dont want it to be cocky, hence keeping my catback.
  5. #5 Re: Exhaust Advice
    a plog and downpipe will barely change the exhaust at all.
  6. #6 Re: Exhaust Advice
    id say removing the u-bend with a DP and replacing the front manifold has to do SOMETHING. so you're saying i should just do a top swap first?
    or were you just talking about sound? if so thats ok with me. more sleeper action.
  7. #7 Re: Exhaust Advice
    PLOG and DP don't really do much for sound I think is what he was getting at...if you plan on top swapping then just get some S&S or Pacesetter's and be done worrying about flow mods.
  8. #8 Re: Exhaust Advice
    Jersey
    Quote Originally Posted by JoRoW99 View Post
    No. Absolutely not. Mine has surface rust, 6 months into use. Its a waste of money. Just get it raw. The high temp paint they use sucks too.
    16' wrx sti- stock
  9. #9 Re: Exhaust Advice
    ok thank you! ^ im not really worried about temps yet, considering i dont even have a $10 mod to buy a new stat. u just saved me $80.
  10. #10 Re: Exhaust Advice
  11. #11 Re: Exhaust Advice
    Jersey
    wrapping it will sometimes lead to cracking, these plogs are as thin as tin-foil.
    16' wrx sti- stock
  12. #12 Re: Exhaust Advice
    Jersey
    np sir
    16' wrx sti- stock
  13. #13 Re: Exhaust Advice
    ok now about the DP...i know i want a 3" bolt on with cat. but should i spring $50 for 304 steel? or is aluminized good enough? i drive in the snow in the winter if that helps (screw nebraska weather)
  14. #14 Re: Exhaust Advice
    Jersey
    your gt might be doggin it with a 3" until you have boost. I have a steel one from zzp.
    16' wrx sti- stock
  15. #15 Re: Exhaust Advice
    Quote Originally Posted by 99prixgt View Post
    explain plz?
  16. #16 Re: Exhaust Advice
    Jersey
    You might be loosing out on torque with that big of a d/p. The only time it will feel quicker is at WOT, other than that it might be sluggish just dd'ing around town.
    16' wrx sti- stock
  17. #17 Re: Exhaust Advice
    not true. buy a 3" downpipe.
  18. #18 Re: Exhaust Advice
    any proof/evidence/reasoning for any of these^ statements? because they are exact opposites.
  19. #19 Re: Exhaust Advice
    GTX Level Member nicksilvergt99's Avatar
    Reading, PA
    im looking at the same mods and i dont plan on top swapping so should i opt for the 2.5? oh and btw bio i never got to thank you for that pm about rims...so thanks!!!
    "This shocker crap is for high school kids, it's all about the double gauntlets, that's right, 2 fists forearm deep, someone make me a sticker. double gauntlets > shocker"
  20. #20 Re: Exhaust Advice
    hey thanx for jacking my thread.. lol jk dude
  1. exhaust advice
    By m3ta77ica in forum General Tech Discussion
    Last Post: 07-09-2009, 08:26 AM
  2. VRS EXHAUST- Mandrel Exhaust kit.
    By Lion29GTP in forum General Tech Discussion
    Last Post: 03-18-2009, 02:47 AM
  3. VRS EXHAUST- Mandrel Exhaust kit.
    By Lion29GTP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-18-2009, 02:43 AM
  4. exhaust advice
    By Scott B in forum General Tech Discussion
    Last Post: 05-28-2008, 09:45 PM
