Thread: Swapping engines
Results 1 to 5 of 5
  1. #1 Re: Swapping engines
    Donating Users mystic231's Avatar
    Michigan
    Welcome to the site! Here's some info on the "top-swap".
    1) - Top Swapped 3800 V6 (GT Only) – Don’t cry you non-supercharged guys, there is still hope on how to lay a smack down on a factory supercharged car and that lies within your block. Yup, Compression Ratio. Higher Compression means a few things for you who go the top swap route. One, you will make more power on the same sized pulley as the factory L67 powered car. Two, High Comp. loves boost. It is easier to blow motors with too much boost and high compression but when tuned correctly is a very lethal combination that will beat most cammed and intercooled L67 cars. Here is the thread I would more than advise reading on the Top Swap (There is also a lot of great info in this thread too): http://www.grandprixforums.net/f17/t...lots-7763.html (Top Swap Info and Faqs, Also lots of 3800 Info) . This isn’t the easiest thing to do, nor is the hardest, you do have to tear the block down to the heads. Cost: $700+
    Also I am under the impression that the tranny's are different as well. Is it just the gearing and ratios that are different or is the GS tranny built better to hold the power of the supercharged motor?
    The GS has 2.93 gears, the GT has 3.29 gears. The GS has a HD transmission that is marginally stonger along with heavy duty halfshafts.
    '98 Bright Red GT 278,000 miles and counting...
    '02 Galaxy Silver GTP GMPP Suspension, F Body front brakes, TDC FWI intake, Ported M90, Intake, and Throttlebody, Overkill PCM
    '02 Bright Red GT
  2. #2 Re: Swapping engines
    missouri
    well here's what my thought process is..... my gt has 220k+ on it and the regal gs has a little shy of 110K on it. i got my gt with 120 on it from an old lady who drove it back and forth from visiting family, then i have ran the piss out of it. The regal gs that is wrecked was also owned by an older couple who more than likely haven't ran the crap out of it and should be in great condition. by doing this swap i was hoping to buy some more time before i buy my dream car, a V8 Grand Prix GXP. I wanted to just do the engine swap and leave my gt tranny in there since it was replaced about 65k ago and has the higher final gear ratio but i'm getting advice that if i go through with the swap it would be easier and better to do a complete motor and tranny swap. I would like to do some minor mod's like a new pulley and pcm but nothing major because i do plan on buying a new gp in a year or so. essentially I am hoping to part out what's good on the GS to pay for installation of the motor/tranny (which my former boss and I will be doing so it should be much) as well as the initial purchase of the car. Thanks for the thread responses!!!
  3. #3 Re: Swapping engines
    Reprogram the PCM. Simple for some, quick and easy.
    BTW..if the interior is gray and the cupholder isn't broken, please pm me. I've always got a Regal with a broken cupholder.
  1. 94 Olds 442 462ci-4wd-2 (twin) engines
    By turbocharged406sbc in forum Oldsmobile Cutlass
    Last Post: 07-10-2014, 05:52 PM
  2. 10 cars that dont deserve their engines
    By SlowM90 in forum Off Topic Discussion
    Last Post: 01-13-2009, 02:37 PM
  3. Jasper Engines....anyone know anything about them?
    By Zef_66 in forum Off Topic Discussion
    Last Post: 08-13-2008, 04:23 PM
  4. Bring on the Carnage!! part 2 Engines
    By TurboKent in forum General Tech Discussion
    Last Post: 03-24-2008, 06:19 PM
  5. Some bling for these engines...
    By GR8racingfool in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-20-2008, 10:13 PM
