Thread: good avice on engine mods *not doing a top swap*
Results 1 to 12 of 12
  1. #1 good avice on engine mods *not doing a top swap*
    GT Level Member GrandPrixGT00's Avatar
    New Jersey
    lookin to get som extra HP and in a week or two im lookin to get the TDC intake (so TDC u dont have to pop in lol but ur advice is greatly appreciated) and im not really sure what else to do or if the TDC intake will do much b/c i dont have any mods at all yet
  2. #2 Re: good avice on engine mods *not doing a top swap*
    Barksdale AFB, LA
    If you don't want to get any sort of forced induction, this would be my preferred list.
    2.5" DP (no need for 3")
    Plog
    some sort of intake
    ER rockers
    HV3
    ported throttle body
    It'd be quick for N/A.
    2009 Subaru Impreza WRX STI
  3. #3 Re: good avice on engine mods *not doing a top swap*
    Wausau, WI
    Quote Originally Posted by Sabrewings View Post
    2.5" DP (no need for 3") DP=Downpipe to replace stock exhaust downpipe and U-bend delete
    Plog Plog= Powerlog which replaces front exhaust manifold
    some sort of intake
    ER rockers
    HV3 Insert for upper intake manifold
    Hope this helps..............
  4. #4 Re: good avice on engine mods *not doing a top swap*
    New Jersey
    nows all i need is a trandlator for those abbreviations lol
  5. #5 Re: good avice on engine mods *not doing a top swap*
    May 2008
    staten island,NY
    i had all those mods when i was N/A....it was ok...the M90 was the greatest mod i ever did
  6. #6 Re: good avice on engine mods *not doing a top swap*
    TDCRacing
    Guest
    Well basicly the only thing you can do is exhaust and intake. That is what's going to make the biggest difference anyway.
    Whether your s/c'd or N/A'd the cooler the air the better. You will notice a difference in performance with our Intake.
    The above rockers that were mentioned is basicly giving you the best performance you can get without buying a cam and tearing into the motor.
  7. #7 Re: good avice on engine mods *not doing a top swap*
    GT Level Member BoostedComp's Avatar
    Youngstown
    yeah that setup wont be too bad for n/a... but no matter what every time you hop into a gtp youll want that top swap... id say bite the bullet and swap or sell and get a gtp... it was well worth it for me
  8. #8 Re: good avice on engine mods *not doing a top swap*
    its a pretty big waste of money to try and get any power out of the n/a motor.
  9. #9 Re: good avice on engine mods *not doing a top swap*
    Youngstown
    i agree... i had a solid 700 bucks wrapped up into my gt before i finally decided to get a gtp.. couldnt really top swap cause i had the 97... what i would do if i had that money layin around for the gtp
  10. #10 Re: good avice on engine mods *not doing a top swap*
    General Tech Sticky.
    Safely Modding Your 3800 Powered Car.
    Read.
  11. #11 Re: good avice on engine mods *not doing a top swap*
    Jersey
    Sabrewings summed it up pretty well, you'd prolly have a high/mid 14 sec car.
    When I was N/A my best was a 15.3 with a 2.2 60ft and traped 88, that was on a cool night. My mods were removed headlight, stock air box, plog, zzp dp, intense s/k, overkill pcm, solid motor mounts, slp catback (not that that matters), and 4* of knock.
    16' wrx sti- stock
  12. #12 Re: good avice on engine mods *not doing a top swap*
    Oxon Hill, MD
    I ran a 14.8 at 91 mph with a 2.09 60' with a 3" downpipe, Wizaired Intake, koni adjustables, S1 throttle body, Corsa catback, and a powerlog. I was running a ZZP pcm with some adjustments to the MAF table when I made that run. I'd say there was definitely room for improvement.
    I wanted to stay NA, but I got a good deal on some top swap parts and decided to take the leap. I'm still gathering parts for the build so I can't say how much faster it is.
  1. 5.7 Engine swap..
    By mr_gtp in forum General Tech Discussion
    Last Post: 04-06-2009, 03:48 AM
  2. Engine Swap
    By 04BlackComp_G in forum General Tech Discussion
    Last Post: 04-04-2009, 09:56 AM
  3. suporting mods for top swap
    By 05grndprix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-26-2009, 11:39 AM
  4. engine swap
    By 3800John in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-03-2008, 02:53 PM
  5. mods for engine
    By Grandprixboy1224 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-13-2008, 07:43 AM
