Thread: Why am I getting Code p0114 after installation of K&N CAI
Results 1 to 10 of 10
  1. #1 Why am I getting Code p0114 after installation of K&N CAI
    SE Level Member GPdude97's Avatar
    NC
    Alright, here's my dilemma. I recently installed a K&N CAI in my 97 GT and I keep getting a code for the IAT sensor, p0114. The IAT was installed in the place provided by the kit, right before the throttle body. I looked this code up on the internet and i was told to replace the sensor and the connector on the wiring harness, which I have done to no avail. Anyone willing to drop some advice, by all means please.
  2. #2 Re: Why am I getting Code p0114 after installation of K&N CAI
    The P0114 code is actually "Raped by K&N's overpriced junk" code. Should read some of the threads on here about it.
    Not sure if you have done both. Do all of the wires look ok that run into the loom over the upper intake?
  3. #3 Re: Why am I getting Code p0114 after installation of K&N CAI
    GT Level Member BoostedComp's Avatar
    Youngstown
    what he said... ^^^. i would go over the wires to make sure they are not damaged. check the end of the sensor also... i wouldnt say as much that its getting a bad reading... for a short time on my gt before i found my stock airbox to put back on i actually just had the iat sensor sitting inside my cone intake and it didnt throw any codes whatsoever
  4. #4 Re: Why am I getting Code p0114 after installation of K&N CAI
    Yours is inside the intake? Mine is ziptied to the throttle bracket...IAT's...psssssssssh
  5. #5 Re: Why am I getting Code p0114 after installation of K&N CAI
  6. #6 Re: Why am I getting Code p0114 after installation of K&N CAI
    Youngstown
    haha damn you got me beat
  7. #7 Re: Why am I getting Code p0114 after installation of K&N CAI
    NC
    Alright i fixed the problem with the code. As it turns out bluegtp91 was right. It was the K&N system that did it. I took the intake out with the intention of putting the factory one back in and I noticed something on the PCM. The wires on the wiring harness that connect to the PCM had been worn through by the K&N filter and were shorting out. This was causing the SES light and it was also messing with the transaxle. I taped all of the exposed wires and now it runs like new. Didnt cost a thing to fix.
  8. #8 Re: Why am I getting Code p0114 after installation of K&N CAI
    in a house
    Quote Originally Posted by GPdude97 View Post
    bluegtp91
  9. #9 Re: Why am I getting Code p0114 after installation of K&N CAI
    NC
    I have to give some credit to BoostedComp too. That advice turned out to be sound seeing that there was a short in the wiring harness.
  10. #10 Re: Why am I getting Code p0114 after installation of K&N CAI
    Youngstown
    hey as long as that baby is up and running thats all that counts. congrats on not having to spend a dime either.
  1. Installation Problems
    By ddyke2000 in forum Audio, Security & Visual Electronics
    Last Post: 05-13-2009, 12:12 AM
  2. sub installation
    By riley34 in forum Audio, Security & Visual Electronics
    Last Post: 11-18-2008, 12:14 PM
  3. Speaker Installation??
    By ssm90GT in forum Audio, Security & Visual Electronics
    Last Post: 10-06-2008, 08:16 PM
  4. HV3 Installation
    By wrfdff4 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-18-2008, 09:37 PM
  5. Car Alarm Installation...
    By Guitarist575 in forum General Tech Discussion
    Last Post: 07-06-2008, 10:50 PM
