Thread: 1998 GT 3800 Will not start !!
Results 1 to 8 of 8
  1. #1 Re: 1998 GT 3800 Will not start !!
    GT Level Member skidoojames151's Avatar
    seattle
    sounds like your upper itake went bad and then it hydrauliced which broke the starter...same thing happened to me when my upper intake leaked
  2. #2 Re: 1998 GT 3800 Will not start !!
    Tennessee
    Quote Originally Posted by skidoojames151 View Post
    Thanks skidoojames you are exactly right, the upper plenum went bad and hydro locked the engine. I have the UIM and LIM off and everything cleaned up. Gathering parts now. FYI if anyone is looking for a UIM, Amazon.com has the Dorman 615-180 for $64 with free ground shipping. It was 129.95 at Autozone ! I think the Dorman part is the best available deal, reinforced around the EGR area, fiberglass reinforced material, reduced diameter ERG pipe to create an air gap between it and the plastic UIM and it comes with all the gaskets, o rings and even a new PVC valve
    I plan on using the new GM aluminum LIM gasket set, certainly better than the originals and I think better than the 2nd plastic version. I will post pics and progress later. Thanks all!
  1. 3800 vs 3800 Supercharged
    By extreme in forum General Tech Discussion
    Last Post: 07-31-2009, 10:45 PM
  2. new 1998 GT no start !
    By pughman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-30-2009, 01:21 PM
  3. '01 3800 N/A won't start! totally confused...
    By Ragefear in forum General Tech Discussion
    Last Post: 04-04-2009, 10:06 AM
