Thread: 1998 GT 3800 Will not start !!
Results 1 to 8 of 8
  1. #1 Re: 1998 GT 3800 Will not start !!
    Tennessee
    SES Light? Sounds like it could a spark issue...your plugs and wires bad? Just a thought...but I don't think plugs and wires would make it back fire out of the intake.
    Thanks for your quick response! Yes the SES light came on as it was dying. I thought about the wires/plugs but it didn't make sense to me that they would all go bad at once. The plugs are getting fire, well I pulled #5 plug, grounded it with a jumper cable and turned the engine over and the plug fired. Can you get any info from OBDII after disconnecting the battery ? I did this to replace the starter, now with the car not starting I am unsure whether I can get any data from the PCM or not.
  2. #2 Re: 1998 GT 3800 Will not start !!
    russia
    Quote Originally Posted by suntoy68 View Post
    Its def not plugs or wires. Pull your coil packs off and underneith is the ignition modual. If you see that its corroded, lightly sand and clean up.
  1. 3800 vs 3800 Supercharged
    By extreme in forum General Tech Discussion
    Last Post: 07-31-2009, 10:45 PM
  2. new 1998 GT no start !
    By pughman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-30-2009, 01:21 PM
  3. '01 3800 N/A won't start! totally confused...
    By Ragefear in forum General Tech Discussion
    Last Post: 04-04-2009, 10:06 AM
