Thread: new 1998 GT no start !
Results 1 to 18 of 18
  1. #1 new 1998 GT no start !
    Missouri
    just got a 1998 GT with the 3800 for $200.00 ! only thing is , it will not start. have done nothing to it but put in a fresh battery, will spin over fine, but no start. has 217,000 miles on it, put starting fluid in it and it back fired out the intake, i can here the fuel pump run...
  2. #2 Re: new 1998 GT no start !
    Banned - Busted For Scamming
    Feb 2009
    did it act like it wanted to run?
  3. #3 Re: new 1998 GT no start !
    plugs and wires might be totally fouled out...might try that or even a fuel filter could be clogged if it has that many miles on it.
  4. #4 Re: new 1998 GT no start !
    Missouri
    yes it acts like its hitting some, i took out number 1 plug, and it has gas and black stuff all over it ! going to get plugs and wires in the A.M.
    pics of it...
  5. #5 Re: new 1998 GT no start !
    Interior looks good...just need to figure out what is wrong, debadge it, get some new taillights and tint them and the windows and have me detail it for you...it'll be the sex
  6. #6 Re: new 1998 GT no start !
    Feb 2009
    if you do get it running for cheap, it will be a killer deal
  7. #7 Re: new 1998 GT no start !
    OH...totally forgot...
    Kansas City Pontiac Motorsports Club - Home
    ^^ Check it out man!!
  8. #8 Re: new 1998 GT no start !
    Missouri
    got it started ! runs like sh-t, plugs where wet with coolant ! when it started it smokes bad white out the tailpipes....runs like dog, and no power......
    im going with a bad intake gasket leak.....
  9. #9 Re: new 1998 GT no start !
    Missouri
    video....
  10. #10 Re: new 1998 GT no start !
    Yikes...all that smoke...looks like enough smoke to be a head gasket...
  11. #11 Re: new 1998 GT no start !
    Missouri
    looks like it was the intake gasket.....
    looks like the TB is leaking to...
    is this notch suppose to be there ?
    all good for the new intake gasket...
  12. #12 Re: new 1998 GT no start !
    Awesome LOL Might as well tear into it the rest of the way and do it right while it is all off...get the Lower Intake Manifold gasket done too...if the Upper was that bad the lower probably needs it...
  13. #13 Re: new 1998 GT no start !
    Missouri
    where am i going to get all the stuff i need , and what all do i need ?
  14. #14 Re: new 1998 GT no start !
    Quote Originally Posted by pughman View Post
    Get them from a GM Dealership...the Aluminum Lower Intake Manifold gaskets...also pick up some new Coolant Elbows for the LIM whileyour there, just a few bucks. Get some red RTV to seal it up too...Should run ya around $50 or so...
  15. #15 Re: new 1998 GT no start !
    Feb 2009
    arent the plastic UIM's a common fail point?
  16. #16 Re: new 1998 GT no start !
    They tend to warp or crack...mileage honestly doesn't make a difference IMO...My Mom had a '03 LeSabre and bought it with 11K on it in '04...she never drives it so when I bought the GTP in early '07, I worked on it first (kinda like the test mule lol) and notcied her UIM took a crap on her and it only had a little under 26K on it at the time. Leaked coolant all over the rear manny. Swapped new LIM gaskets and put a new UIM on it and VIOLA!! Done like dinner
  17. #17 Re: new 1998 GT no start !
    GT Level Member Swash's Avatar
    Excelsior Springs, MO
    Send a PM to Brian (Reptile).
    x2 on the lower and upper replacement - might as well do it now. Don't forget to change the oil after you change the gaskets - use some low-grade dino-stuff at first, just long enough to circulate and warm up - and then change it and the filter again to a more...sophisticated brand. .
    I'd also run some Seafoam through that sucker when you get it all buttoned up...but that's just me.
    Also - at the beginning of your video - it sounds like either the bendix didn't kick out all the way - or you (possibly) are missing a tooth (teeth) on the flywheel....but I'm old and my hearing isn't that great.
    Good luck, and nice find!!
    -Swash
    I'm sorry, I can't hear you over the sound of how awesome I am...
    2004 IBM/Black/A4 GTO -- 1 of 273 - and the slowest
    2002 Galaxy Silver GTP - a few mods - sold
  18. #18 Re: new 1998 GT no start !
    GT Level Member GPSims39's Avatar
    Nov 2008
    Hauppauge, NY
    damn man, that is a nasty looking gasket, i need to do mine as well, and the valve cover gaskets, mine are shot
  1. 1998 GTP TPS problem
    By kw_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-18-2013, 05:43 PM
  2. My 1998 GTP project...
    By twiggsta in forum Visual/Body Modifications
    Last Post: 03-12-2011, 12:08 AM
  3. 1998 ram air hood?
    By jprovinsal in forum Visual/Body Modifications
    Last Post: 02-07-2009, 01:05 AM
