Thread: Engine/Trams Removal
Results 1 to 7 of 7
  1. #1 Engine/Trams Removal
    Apr 2009
    SE Kansas
    If you remove the master cylinder and possibly the bake booster will the engine & trans come out the top together? Please don't suggest i drop the sub frame.. I have no way to get the sub frame back into position.
  2. #2 Re: Engine/Trams Removal
    TDCRacing
    Guest
    You can remove them both without removing the master cylinder and brake booster.
  3. #3 Re: Engine/Trams Removal
    Apr 2009
    SE Kansas
    Quote Originally Posted by TDCRacing View Post
    So its as easy as removing all hoses/wires/drive axles/mounts/exhaust and lift it out? That would be awesome.
  4. #4 Re: Engine/Trams Removal
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Quote Originally Posted by WoR View Post
    You'll also want to remove the AC compressor and leave it in the car.
    2001 Buick Regal LS - Almost Stock
  5. #5 Re: Engine/Trams Removal
    TDCRacing
    Guest
    Yes sir.
  6. #6 Re: Engine/Trams Removal
    Banned - Busted For Scamming
    Feb 2009
    yea, just unbolt and lay it on the cradle
  7. #7 Re: Engine/Trams Removal
    Apr 2009
    SE Kansas
    thx for the info guys.
  1. Radio removal
    By longslide10 in forum Audio, Security & Visual Electronics
    Last Post: 12-26-2008, 01:46 AM
  2. Cupholder Removal?
    By Abrasive in forum General Tech Discussion
    Last Post: 12-10-2008, 11:42 PM
  3. engine removal
    By stanwich in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-11-2008, 11:23 PM
  4. Dash Removal?
    By Bogers99GTP in forum General Tech Discussion
    Last Post: 10-21-2008, 05:58 PM
  5. 60 V6 Engine Water Pump Removal And Install [*]
    By 19SE92 in forum How To Write-Ups/Tech Tips
    Last Post: 03-09-2008, 09:15 AM
