Thread: 1997 SE 3.8 with really bad mileage, what can i do?
Results 1 to 7 of 7
  1. #1 1997 SE 3.8 with really bad mileage, what can i do?
    Apr 2009
    WI
    last year i picked up a 1997 grand prix SE with the 3.8
    and ever since i got it the mileage has been really bad, on a road trip, the best i can do is 23, usually its like 20, and i drive pretty normal. and i keep my tires at 40 psi
    I changed the plugs on the car and the air filter, and that didn't have any effect on it. i noticed that the intake manifold gasket has a light leak and i'm going to replace it, could that be causing the really bad mileage?
    if not any other ideas on what could be wrong with it?
    thanks
  2. #2 Re: 1997 SE 3.8 with really bad mileage, what can i do?
    Fuel filter? Try that too...
  3. #3 Re: 1997 SE 3.8 with really bad mileage, what can i do?
    Apr 2009
    WI
    i will try that, i didn't realize that a fuel filter can make the mileage go down....
  4. #4 Re: 1997 SE 3.8 with really bad mileage, what can i do?
    Change the oil and oil filter...clean out the throttle body...you'll see all of the gunk. I'd get new plugs wires and pull of the coil packs and try cleaning those too. And if all else fails throw some Lucas Fuel System cleaner in the gas tank. I used that on my old Buick ('86 Iron Duke 4 banger) and it gave it AT LEAST 3-5mpg better after I ran it though...although they recommended it for F.I. cars I had T.B.I. and it worked just fine
  5. #5 Re: 1997 SE 3.8 with really bad mileage, what can i do?
    Apr 2009
    WI
    what should i use to clean out the throttle body?
  6. #6 Re: 1997 SE 3.8 with really bad mileage, what can i do?
    SE Level Member Pontiacman's Avatar
    Amarillo, Texas
    The tires don't need to be at 40psi. They need to be about 30-32 psi.
  7. #7 Re: 1997 SE 3.8 with really bad mileage, what can i do?
    Apr 2009
    WI
    i have always done the 40 psi on my cars and usually gained me an extra mpg, but on this thing didn't make a difference, so maybe i should lower it
  1. fuel milage
    By justwhisen in forum Off Topic Discussion
    Last Post: 04-07-2009, 09:42 AM
  2. ZZP HV3 intake milage
    By MnRedGP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-08-2009, 06:02 PM
  3. Gas Milage
    By Hamm61 in forum Off Topic Discussion
    Last Post: 08-19-2008, 01:24 PM
  4. just bought a 1997 gtp
    By goodwrench in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-21-2008, 07:58 AM
