Thread: Replacing O2 sensors
Results 1 to 8 of 8
  1. #1 Replacing O2 sensors
    SE Level Member rnovember's Avatar
    Ottawa, ON
    My check engine light came on awhile ago and I'm getting bad gas mileage. I don't have a code-reader or anything, but my hunch is a bad O2 sensor. Is replacing these sensors something that's easy to do yourself? I realize there's 2 or 3 of them and I'd likely have to replace them all. Or is it worthwhile to take it to the garage and have them scan it and charge me an arm-and-a leg. Any comments would be appreciated.
    Replacing O2 sensors Attached Images
  2. #2 Re: Replacing O2 sensors
    GTX Level Member WhiteDevil's Avatar
    Aug 2008
    60118 NE Illinois
    got an autozone by you?
  3. #3 Re: Replacing O2 sensors
    Ottawa, ON
    Sorry, no autozone where I am.
  4. #4 Re: Replacing O2 sensors
    GT Level Member WhiteGT's Avatar
    May 2008
    Ontario
    Call around and find a place that reads codes and go from there. You should have partsource or something like that I think. Sometimes garages will do it free.
  5. #5 Re: Replacing O2 sensors
    SE Level Member CaStylin's Avatar
    Sugar Land, TX
    I would go get it scanned or pick up a $40 scanner from a local parts store... don’t want to go replacing things that don’t need to be replaced
    Also you have 2 O2 sensors... the rear one (just behind the cat) is for emissions (and pretty much useless since it makes no PCM adjustments) the other (upper O2) is attached to your rear manifold... it reads and makes adjustments your fuel to air ratio... if this one is bad i suggest replacing it as soon as possible... mine went out, i ordered a new one but continued to drive it in the mean time... end result, the engine went lean and i bent up a rod
    Hope this helps
    CaStylin
  6. #6 Re: Replacing O2 sensors
    Nov 2008
    Chicago
    They can be a pain to replace if its stuck. You can use a standard wrench or you can buy a special socket for it.
  7. #7 Re: Replacing O2 sensors
    Ottawa, ON
    Thanks everyone. I think I'll pick up a scanner and go from there. At least if it is the O2 sensor I'll know to replace only the one on the rear manifold. I'm assuming that AC Delco is the most suitable brand of sensor for the Grand Prix. I've heard bad things about the Bosch ones ...
  8. #8 Re: Replacing O2 sensors
    Sugar Land, TX
    You would know if its the upper manifiold O2 if your MPG has been continuing to drop since the light came on.
    The rear O2, although IMO usless, acts as a warning system and will still set a check engine light (Code P240)... and cause you to fail inspection in most citys/states
    Find out which one it is an replace it... if you have a 00-03 then you can buy a o2 simulator for the rear one... its a little cheaper and if you ever get a downpipe then you have already gotten rid of the code that it will throw
    Also... your are correct about the AC delco thing... go with the OEM... the bosch's are crap for most GM applications
  1. How many O2 sensors??
    By Tullphan in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-29-2009, 12:32 AM
  2. I want your sensors
    By SyntheticShield in forum General Tech Discussion
    Last Post: 02-05-2009, 01:53 PM
  3. 2 map sensors??
    By sickofsoyo in forum General Tech Discussion
    Last Post: 01-24-2009, 09:28 PM
  4. sensors?????
    By blowfishRus6 in forum General Tech Discussion
    Last Post: 09-28-2008, 01:00 PM
