Thread: Replacing O2 sensors
Results 1 to 8 of 8
  1. #1 Re: Replacing O2 sensors
    SE Level Member rnovember's Avatar
    Ottawa, ON
    Thanks everyone. I think I'll pick up a scanner and go from there. At least if it is the O2 sensor I'll know to replace only the one on the rear manifold. I'm assuming that AC Delco is the most suitable brand of sensor for the Grand Prix. I've heard bad things about the Bosch ones ...
  2. #2 Re: Replacing O2 sensors
    SE Level Member CaStylin's Avatar
    Sugar Land, TX
    You would know if its the upper manifiold O2 if your MPG has been continuing to drop since the light came on.
    The rear O2, although IMO usless, acts as a warning system and will still set a check engine light (Code P240)... and cause you to fail inspection in most citys/states
    Find out which one it is an replace it... if you have a 00-03 then you can buy a o2 simulator for the rear one... its a little cheaper and if you ever get a downpipe then you have already gotten rid of the code that it will throw
    Also... your are correct about the AC delco thing... go with the OEM... the bosch's are crap for most GM applications
  1. How many O2 sensors??
    By Tullphan in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-29-2009, 12:32 AM
  2. I want your sensors
    By SyntheticShield in forum General Tech Discussion
    Last Post: 02-05-2009, 01:53 PM
  3. 2 map sensors??
    By sickofsoyo in forum General Tech Discussion
    Last Post: 01-24-2009, 09:28 PM
  4. sensors?????
    By blowfishRus6 in forum General Tech Discussion
    Last Post: 09-28-2008, 01:00 PM
