I did some searching and could not find this. If I am looking at the engine which is Cylinder #6? I have the famous misfire code. Also, is there a simple post or somewhere that shows the order of the coil packs and which cylinders they drive from top to bottom? I want to swap the coil packs around too and see if it helps.
