Thread: Cylinder order looking at engine?
Results 1 to 6 of 6
  1. #1 Cylinder order looking at engine?
    Feb 2009
    NE
    I did some searching and could not find this. If I am looking at the engine which is Cylinder #6? I have the famous misfire code. Also, is there a simple post or somewhere that shows the order of the coil packs and which cylinders they drive from top to bottom? I want to swap the coil packs around too and see if it helps.
  2. #2 Re: Cylinder order looking at engine?
    TDCRacing
    Guest
    Edited.Wrong link.
    Be sure to check you're spark plugs for them being cracked. Otherwise you more than likley have a bad coil pack.
  3. #3 Re: Cylinder order looking at engine?
    May 2008
    staten island,NY
    rear right is six
    2 4 6-firewall
    1 3 5-radiator fans
  4. #4 Re: Cylinder order looking at engine?
  5. #5 Re: Cylinder order looking at engine?
    Barksdale AFB, LA
    Also, the coil packs should be numbered which cylinders they work with. Also the wires should be numbered.
    2009 Subaru Impreza WRX STI
  6. #6 Re: Cylinder order looking at engine?
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Quote Originally Posted by Sabrewings View Post
    Only if they're stock.
    2001 Buick Regal LS - Almost Stock
  1. Firing order
    By TDCRacing in forum How To Write-Ups/Tech Tips
    Last Post: 06-10-2010, 12:31 PM
  2. Beautiful day, detailed, 56k order a pizza
    By Sabrewings in forum Off Topic Discussion
    Last Post: 04-22-2009, 05:12 PM
  3. Anyone order from these guys?
    By tonkota in forum General Tech Discussion
    Last Post: 03-02-2009, 07:53 PM
  4. Heres my Mod order list. Looking for suggestions.
    By 04CompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-07-2008, 08:33 AM
  5. ECM service number for re-order
    By catcamvegas in forum General Tech Discussion
    Last Post: 08-06-2008, 01:35 PM
