Thread: Changing Spark Plug Wires, HELP!
Results 1 to 9 of 9
  1. #1 Changing Spark Plug Wires, HELP!
    Feb 2009
    WA
    I was planning on doing an ignition coil and spark plug wire swap today but had to nix the wires because of time and those dang things seem to be seized onto the plugs! Is there some special trick to getting them off the plugs or do I just need to pretend I am a contortionist and keep pulling straight until they come off or I can't use my fingers anymore?
    PGT
  2. #2 Re: Changing Spark Plug Wires, HELP!
    Charles City, IA
    twist and pull then take a break swear at them and pull again. Don't be surprised to break some of the wires. Also make sure to tilt the engine forward for the backs.
    SMGPFC Two Nipple General
  3. #3 Re: Changing Spark Plug Wires, HELP!
    Nov 2008
    Chicago
    Like I said, pull on the top of the boots and not the wire
  4. #4 Re: Changing Spark Plug Wires, HELP!
    Charles City, IA
    Quote Originally Posted by FuglyGTP View Post
    I have also torn boots. Either way the stock wires just plain suck.
  5. #5 Re: Changing Spark Plug Wires, HELP!
    Feb 2009
    WA
    Ha!! I think I found the answer to getting those dang wires off! I got a spark plug boot removal tool from Summit Racing. We'll see if those little bastards stay on this time!
    Summit SUM-900071 - Summit® Spark Plug Boot Removal Tools - summitracing.com
    I was thinking of this tool, but went with the other.
    Taylor Cable 43392 - Taylor Spark Plug Boot Removal Tools - summitracing.com
    PGT
  6. #6 Re: Changing Spark Plug Wires, HELP!
    Feb 2009
    WA
    Uh, tilt the engine? How do I do that, is there a how to link?
    PGT
  7. #7 Re: Changing Spark Plug Wires, HELP!
    Nov 2008
    Chicago
    I took some pliers clamped down onto the top of the boot and basically used the nose of the pliers as a handle to pull the boots off. Remember to rock the engine forward to get it away from the firewall. One of the easiest ways is to have someone push the car forward while its in park and then hit the parking brake to keep the engine tilted forward.
    I also had to extend the handle on my ratchet to get enough torq to get the 12 year old plugs out. Be very careful if you have to use this method. A broken spark plug in your engine is no fun.
  8. #8 Re: Changing Spark Plug Wires, HELP!
    Nov 2008
    Chicago
    Read my post above for the quick method. see the link below for the slightly more complicated and more effective method
    http://www.grandprixforums.net/f95/t...ward-4905.html
  9. #9 Re: Changing Spark Plug Wires, HELP!
    Nov 2008
    Chicago
    most parts stores carry some type of boot puller. Ive never seen the taylor ones before. they're pretty sweet
  1. Plug wires
    By 04muscle in forum General Tech Discussion
    Last Post: 03-09-2009, 01:02 AM
  2. Plug Wires
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-12-2008, 11:56 PM
  3. Changing the Spark plugs
    By adidasdude1061 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-01-2008, 03:24 AM
  4. Plug wires
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-17-2008, 03:12 PM
