Thread: No spark
Results 1 to 4 of 4
  1. #1 No spark
    Dec 2016
    Michigan
    So last week was driving along and the car just stalled. Wouldn't restart. Got it towed home and started checking it out.
    Poor fuel pressure, so it got a new pump and filter. Still no start, checked the ignition. Nothing at the coil, ground under the icm was fine. Cps harness looked good, changed the cps and the balancer(puller stripped out the threads). Still nothing. Swapped in a spare icm and still nothing.
    I'm out of ideas other than broken wire harnesses. Not throwing any codes, and according to my torque app its calling for 0 degrees of timing while cranking, if that helps. Any help would be appreciated.
    02 GPGT, Shift kit, Standalone trans cooler, Home Depot Racing hai, Custom tune with DHP.
  2. #2 Re: No spark
    St. Louis
    You check all the fuses?
  3. #3 Re: No spark
    Dec 2016
    Michigan
    Yeah. But considering I was on a busy road when I did, rechecking might be a good idea.
  4. #4 Re: No spark
    Dec 2016
    Michigan
    Got it running. Turns out the main ignition relay went bad. Feel like a fool, but at least this fool has a car that runs like a watch.
  1. No Spark
    By GreenGTP91 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2013, 01:18 PM
  2. 08 with no spark
    By JJB in forum General Tech Discussion
    Last Post: 03-28-2012, 10:27 PM
  3. 3.1 and no spark
    By TAYLORPCC in forum 3.1L V6 (LHO/LG8)
    Last Post: 11-25-2010, 01:45 AM
  4. 72 gp sj no spark
    By rayzo63 in forum General Tech Discussion
    Last Post: 02-16-2009, 10:40 PM
  5. no spark
    By faboskay57 in forum General Tech Discussion
    Last Post: 07-10-2008, 07:41 AM
