Thread: Need help with a P0300 code
Results 1 to 20 of 33
  1. #1 Re: Need help with a P0300 code
    SE Level Member derpyimp's Avatar
    Nov 2017
    Utah
    I just got done swapping over my coil packs and ICM from the Pontiac to the Impala. It's still misfiring, and I know those parts are good. Any other ideas? Anyone know if the computer would throw a code if the crank position sensor was bad?
    '04 GTP Comp-G - 14.871 @ 93.30 (6600 ft DA) - 3.6 MPS, SD headers w/ high-flow cat, Gutted stock airbox, Transgo shift kit, AL 104s, 180 tstat, GMPP front sway bar, poly control arm bushings, Tune by Dyno Brian
  2. #2 Re: Need help with a P0300 code
    Nov 2017
    Utah
    Also, here is a scan of it misfiring at WOT. You can see where the engine RPM starts to struggle and the MAF readings match it.
    http://i346.photobucket.com/albums/p...psgkpl64zm.png
  1. Relentless P0300 code
    By gofast in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-11-2016, 08:50 AM
  2. P0300 code , need help !!
    By damohr in forum General Tech Discussion
    Last Post: 03-04-2015, 07:44 PM
  3. someone help? p0300 code
    By ericg1181 in forum General Tech Discussion
    Last Post: 04-07-2014, 02:09 PM
  4. Stumped with P0300 code
    By zach101 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-20-2011, 04:56 PM
  5. 4-5k rpm misfire, Code P0300.
    By trailshredder in forum Engine
    Last Post: 11-13-2011, 07:43 PM
