Thread: Need help with a P0300 code
Results 1 to 20 of 33
  1. #1 Re: Need help with a P0300 code
    Kemmerer, Wyoming
    if you have a scanner, I would scan the LTFT's to see if they go to 0 under wot and what they are during normal driving.
  2. #2 Re: Need help with a P0300 code
    SE Level Member derpyimp's Avatar
    Nov 2017
    Utah
    Quote Originally Posted by SgtMarshal View Post
    I just went to drive it again and it was missing really bad even under very light throttle. Here's the scan from when I tried going WOT, starting at about the 5 mark on those line graphs.
    http://i346.photobucket.com/albums/p...pstsxgwxd2.png
    '04 GTP Comp-G - 14.871 @ 93.30 (6600 ft DA) - 3.6 MPS, SD headers w/ high-flow cat, Gutted stock airbox, Transgo shift kit, AL 104s, 180 tstat, GMPP front sway bar, poly control arm bushings, Tune by Dyno Brian
  1. Relentless P0300 code
    By gofast in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-11-2016, 08:50 AM
  2. P0300 code , need help !!
    By damohr in forum General Tech Discussion
    Last Post: 03-04-2015, 07:44 PM
  3. someone help? p0300 code
    By ericg1181 in forum General Tech Discussion
    Last Post: 04-07-2014, 02:09 PM
  4. Stumped with P0300 code
    By zach101 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-20-2011, 04:56 PM
  5. 4-5k rpm misfire, Code P0300.
    By trailshredder in forum Engine
    Last Post: 11-13-2011, 07:43 PM
