Thread: Weak Start Up/Start Up Issues
Results 1 to 11 of 11
  1. #1 Weak Start Up/Start Up Issues
    SE Level Member PontiacZack's Avatar
    Jun 2016
    San Antonio, TX
    Hi, all
    I've been having some issues lately with my 07' start up. It has been sounding weak compared to my friends 4 cylinder 😂 and the other issue is that it will start up but, then die immediately and I just had my fuel injectors cleaned. This is important to mention as well, I have to press the gas to get it to start. I've also attached a YouTube link to my cars start up if you would like to check it out. The video sounds a lot better than the actual start up.
    2007 Pontiac Grand Prix Bad Start Up - YouTube
    Any ideas on how to solve this issues would be greatly appreciated.
  2. #2 Re: Weak Start Up/Start Up Issues
    The Boss Iceman6669's Avatar
    Jun 2011
    Have you tried starting it without the MAF plugged in? That will cause a car to die right after starting sometimes.
    2011 F-150 Yote powered
  3. #3 Re: Weak Start Up/Start Up Issues
    Jun 2016
    San Antonio, TX
    @Iceman6669
    So, we tried unplugging the MAF and starting it up and still received a weak start up.
    Here's my friends car start up for comparison. He use to own a grand prix as well and he is confused as to why the start up is so weak and his Pontiac had over 200K miles
    2013 Chevy Sonic W/80K miles Start up - YouTube
  4. #4 Re: Weak Start Up/Start Up Issues
    You video sounds fine to me. except that you say you are using throttle to start it.
    When you did the injectors, why did you do them?
    What did you take off to put them in? These are all things you should double check
    Likely you moved a vacuum line etc.. check those.. a huge vac leak could cause a fire up and stall.
  5. #5 Re: Weak Start Up/Start Up Issues
    Jun 2016
    San Antonio, TX
    @Billbost37 Before the fuel injectors cleaning, I was having a weak start up and thought cleaning the injectors would help. The work was performed by a local mechanics shop. It's actually running better now.
  6. #6 Re: Weak Start Up/Start Up Issues
    your comparing apples and a potato.
  7. #7 Re: Weak Start Up/Start Up Issues
    Jun 2016
    San Antonio, TX
    Disregard the comparison. The issue is I have to give the car throttle to start it half the time. Could it be a fuel filter issue?
  8. #8 Re: Weak Start Up/Start Up Issues
    St. Louis
    You don't have an external fuel filter. IIRC late 04+ moved it inside the tank (aka- not serviceable). Has the TB ever been cleaned? Any codes showing? When was the last time a tune-up was done? Do you know if the shop actually removed the injectors? If so they should have replaced both O-rings. And yea, that video sounds just fine for start up. Even my GT with 350K miles sounds like that. Although I don't have to give it any throttle to start it.
  9. #9 Re: Weak Start Up/Start Up Issues
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    The problem it's having is with the throttle body. If the TB is dirty and has a lot of build-up behind the blade, it'll cause the car to die immediately after start-up, Not sure why, could be something with the TPS built in to the TB, or the valve not returning to the exact idle position that it's expecting because of the crap blocking it...
    Cleaning the TB is what I would do. If it's really nasty, be careful with the amount of TB cleaner you use, the seal between the shaft and the housing isn't the best and if any liquid gets into the housing, it'll play hell with the servo and circuits in there. I had to take mine apart and let it dry over night before it would do anything.
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  10. #10 Re: Weak Start Up/Start Up Issues
    Jun 2016
    San Antonio, TX
    @Fordman77
    I don't know if the shop removed the injectors and replaced the o-rings. I would have to go back and ask them. I've only performed minimal maintence for awhile but, I'm really working hard to put some serious maintence in now.
    @WarStryker13
    Thank you for the info! I'm try cleaning the TB and letting it sit over night and see the results I get.
  11. #11 Re: Weak Start Up/Start Up Issues
    I agree, very likely your TB is dirty.
  1. Remote start issues
    By Timing in forum Audio, Security & Visual Electronics
    Last Post: 03-31-2015, 12:17 PM
  2. Start up issues
    By synfullj187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-09-2014, 11:58 PM
  3. Start up issues
    By Hfoustrn in forum Introductions/Noob Questions
    Last Post: 09-08-2013, 09:26 PM
  4. 00 GTP issues with a rough start every now and then
    By goshjosh234 in forum General Tech Discussion
    Last Post: 01-27-2013, 02:02 AM
  5. warm start weak idle 50/50 will stall immediately
    By Crims in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-07-2011, 02:47 AM
