Thread: Start up issues
Results 1 to 5 of 5
Hfoustrn Start up issues 09-08-2013, 09:14 PM
REDCRAPGP Re: Start up issues 09-08-2013, 09:17 PM
NegativeOne13 Re: Start up issues 09-08-2013, 09:20 PM
REDCRAPGP Re: Start up issues 09-08-2013, 09:22 PM
Hfoustrn Re: Start up issues 09-08-2013, 09:26 PM
  1. #1 Start up issues
    Sep 2013
    Delphos, Ohio
    I recently bought a 2004 grand prix gt2.. When starting the engine all the gauges max out and return to normal but that being said its also sluggish to start resulting in me having to give it gas to start it and/or to keep it running. I added some injector cleaner to a tank of gas that was 3/4 way full. I had filled the tank the day before. When j picked up the car it had 1/4 tank... Any suggestions would be appreciated, thanks
  2. #2 Re: Start up issues
    Sounds like a fueling issue. Check the fuel pressure at the rail and then start the car again and check it. Could be a dying fuel pump. What's the mileage?
    04 Comp G.
  3. #3 Re: Start up issues
    Kansas
    Clean your MAF sensor and throttle body. Search the forums as what you describe sounds like a common problem. Clean MAF with electronic safe cleaner, clean all the carbon buildup on throttle body with carb cleaner.
  4. #4 Re: Start up issues
    Quote Originally Posted by NegativeOne13 View Post
    Forget to mention this!! Easy and quick possible solution.
    04 Comp G.
  5. #5 Re: Start up issues
    Sep 2013
    Delphos, Ohio
    It has 153,000 miles and i didnt notice the issue until i filled the tank, hence why i went ahead and added the injector cleaner.. Who knows the last time it had a full tank of gas in it.. Thanks for the suggestions! Will try them out asap!
  1. 00 GTP issues with a rough start every now and then
    By goshjosh234 in forum General Tech Discussion
    Last Post: 01-27-2013, 02:02 AM
  2. 1999 GTP Hard to start issues. I am at a loss. Need help!!!!!
    By curticra in forum General Tech Discussion
    Last Post: 01-14-2013, 10:04 AM
  3. Remote Start Issues
    By stewy58 in forum 5.3L V8 (LS4)
    Last Post: 11-01-2011, 06:29 AM
  4. power window issues, where to start?
    By christopher8911 in forum General Tech Discussion
    Last Post: 07-05-2011, 09:08 AM
  5. Remote start issues
    By lil sabby in forum General Tech Discussion
    Last Post: 03-02-2010, 11:05 AM
