Thread: P0420
Results 1 to 7 of 7
  1. #1 P0420
    Feb 2018
    Canada
    I have a 420 code for my cat. I cleared it several times but now it comes back the same day, and now I can notice the engine fluctuate at any speed when just to say on the pedal. My question is can I clean it? Like take it off and clean it out ? This morning I noticed the exhaust coming out around the front engine bay. Tune up done about 2yrs ago. 08 base 3.8. Thanks gang
  2. #2 Re: P0420
    sounds like its time for a new cat. if the car feels weak its the cat for sure.
  3. #3 Re: P0420
    GT Level Member Pursell1911's Avatar
    Jan 2017
    Louisville, Kentucky
    and if the engine makes really loud clanks past 3500 rpm, definitely time for a new cat.
    2006 Grand Prix GT - 3" Downpipe | DIY Intake
  4. #4 Re: P0420
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    just don't do like I did and get a crappy cheap aftermarket weld in design. Walker is the brand I've heard works best.
  5. #5 Re: P0420
    Feb 2018
    Canada
    Thanks for the replies. The cat I have now is a walker cat that I changed about 2 years ago. I read on here that a rotten egg will occur but I don't smell it. When I wot it has a hard time getting past 3500 rpm which is not normal. Does the cat actually clog up to the point were no air gets thru, or just stops cleaning the exhaust as it should. Cause honestly I can't buy one now. But I need the wheels. Can I maybe hammer on the ***** and loosen up the crud lol?
  6. #6 Re: P0420
    Aug 2017
    Raytown, MO
    Quote Originally Posted by Stone 316 View Post
    Definitely DON'T hammer on it. Running with a clogged cat is not a good thing. The two things that will kill a cat early most frequently are coolant being burned or excess fuel, so when you get it fixed, make sure you check your fuel trims and make sure you're not loosing coolant.
    If you're noticing it getting sluggish, it's probably getting clogged. If it gets much worse, I would not recommend driving on it if you don't want to replace your engine, though it usually takes a lot to get that bad. If you're really strapped, see how much just getting a straight pipe welded in would cost. Better than putting backpressure on your engine.
  7. #7 Re: P0420
    Walker cats have like a Limited Lifetime warranty or a 25,000mile warranty, check to see if you are still covered.
  1. P0420
    By Teecraige in forum Introductions/Noob Questions
    Last Post: 06-09-2015, 06:00 PM
  2. 03 gt p0420
    By Fahrenheit in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-22-2014, 11:48 PM
  3. p0420
    By sirricealot in forum General Tech Discussion
    Last Post: 09-09-2013, 04:13 PM
  4. p0420
    By sirricealot in forum 5.3L V8 (LS4)
    Last Post: 04-25-2013, 10:20 AM
  5. P0420. Cat or 02
    By tayl5645 in forum General Tech Discussion
    Last Post: 04-22-2011, 09:20 AM
