Thread: 03 gt p0420
Results 1 to 20 of 28
  1. #1 03 gt p0420
    Jul 2010
    Philly
    Car tossed this same code almost a year ago and I was about to try the ZZP O2 Bung Extender but the light turned off and never came back on, well till now anyways. Car is running fine and when I fist pound the cat I don't get a rattle sound. No rotten egg smell either. Way I look at it I got 3 options. The bung, toss a o2 sensor at it, or get a ZZP PCM to shut off the rear o2 sensor. Think its worth it to try a sensor? Normally if its a sensor it toss the heater circuit code as well. Does the bung hurt MPG or drivability at all? ZZP says right on the site "We do not recommend running without the rear o2 sensor because it could run the rear o2 test and reduce your gas mileage" that worries me about going with the tune option.
    So whats should I do? I guess buying a new cat is an option but a GM cat is like 700 bucks, Amazon shows an
    ACDelco AFS141 for like 33 bucks. I'm not sure if this is upstream or downstream. I think it's the down stream....
  2. #2 Re: 03 gt p0420
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Do you need a cat to pass emssions/inspections.
    2012 F150 STX
    - Gonna be a race truck
  3. #3 Re: 03 gt p0420
    Dec 2010
    DMV
    This. I mean if you don't need it then why bother.
  4. #4 Re: 03 gt p0420
    Cause some folks are responsible and don't like the smell of raw fuel..
    Damn kids!
    04 Comp G.
  5. #5 Re: 03 gt p0420
    Dec 2010
    DMV
    Never. Lol. I have no cat and I don't smell raw fuel. Maybe the people behind me though lol
  6. #6 Re: 03 gt p0420
    Shame on you!
    04 Comp G.
  7. #7 Re: 03 gt p0420
    Jul 2010
    Philly
    Yes I need it for PA inspection.
  8. #8 Re: 03 gt p0420
    Apr 2012
    Dayton, OH
    What all do they test/look for.
    2012 F150 STX
  9. #9 Re: 03 gt p0420
    this is a bank one, aka up stream o2 code. http://www.obd-codes.com/p0420 so why not order up a nice new up stream o2 sensor form rock auto.
  10. #10 Re: 03 gt p0420
    Jul 2010
    Philly
    Quote Originally Posted by Fahrenheit View Post
    Visually check plus plugged into the computer
    Well crap, your right now that I look at it. These cars have 2 sensors right? Might as well replace both at once. ACDelco AFS109 and ACDelco AFS141 right? 30 bucks a pop on amazon.
  11. #11 Re: 03 gt p0420
    being yours is a 03 it uses the rear o2, so if both have the same miles why not. not needed tho. my moto is dont fix what aint broken.
  12. #12 Re: 03 gt p0420
    Jul 2010
    Philly
    So im sorry if im being dumb but how many O2 sensors does my car have? 3 or 2? I was thinking 3, one on each exhaust bank and one post cat. Everyplace I google still says P0420 is a cat code. I got one of them scan tools that link to my phone, gonna check the O2 sensor output reading and see what that says
  13. #13 Re: 03 gt p0420
    Apr 2012
    Dayton, OH
    It has 2
    One on the rear manifold
    One after the cat in the downpipe
    2012 F150 STX
  14. #14 Re: 03 gt p0420
    Catalyst System Efficiency Below Threshold (Bank 1)
    Read more at: http://www.obd-codes.com/p0420
    Copyright © OBD-Codes.com
    bank one means the one in the rear exhaust manifold. read that link.
  15. #15 Re: 03 gt p0420
    Jul 2010
    Philly
    Thanks for the help. I just checked the volts on the o2 sensor. Upstream jumps from 0.1 to 0.9 while the downstream one sits at 0.3 to 0.4 and that's with the car warmed up at 2000 RPMs. When driving around I did notice the Upstream 02 will read 0.0. Not sure if that is an indication of anything. Downstream o2 does bounce around while driving but much less then upstream. I got a temp gun as well to do some additional testing.
  16. #16 Re: 03 gt p0420
    that up steam o2 should be dancing up and down rather fast. if its slow, its no longer working right.
  17. #17 Re: 03 gt p0420
    Jul 2010
    Philly
    The Upstream is moving pretty quick. Not sure how fast it should be moving.
  18. #18 Re: 03 gt p0420
    it should be flashing like 9,7,4,2,9,8,5,3,5. random blips up and down over and over, like less then a second per # change.
  19. #19 Re: 03 gt p0420
    Jul 2010
    Philly
    Yeah it's moving like that. It do a full up and down sweep in like 2 seconds.
  20. #20 Re: 03 gt p0420
    it said something about the heater in the link for the code. so it could be a failing o2 heater too.
  1. p0420
    By sirricealot in forum 5.3L V8 (LS4)
    Last Post: 04-25-2013, 10:20 AM
  2. P0420. Cat or 02
    By tayl5645 in forum General Tech Discussion
    Last Post: 04-22-2011, 09:20 AM
  3. P0420
    By PhunnyJesta in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-16-2011, 08:29 PM
  4. p0420
    By chickenfried in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-22-2010, 04:26 PM
  5. p0420 02 gtp
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-05-2009, 10:52 AM
