Thread: Engine code p0304 and p0300
Results 1 to 20 of 26
  1. #1 Engine code p0304 and p0300
    Nov 2017
    Michigan
    Hi new to the forum. I recently got a 2002 grand prix 3.8l non supercharged. Ive been getting a engine misfire code p0300 and p0304. Ive changed out plugs and wires, put in new coils also. I only get the code,at highway speeds 65 to 70mph im completely stumped at this point. Anyone have this issue or know what i can look for? Thanks in advance.
    Sent from my SM-J700T1 using Tapatalk
  2. #2 Re: Engine code p0304 and p0300
    Swap injectors around to rule those out. Swap the cylinder 4 injector for like cylinder 1 or 3. See if the misfire moves.
    Past that it could be the ignition control module.
  3. #3 Re: Engine code p0304 and p0300
    Nov 2017
    Michigan
    Ok ill give that a try this weekend thank you
  4. #4 Re: Engine code p0304 and p0300
    Mar 2017
    Internet
    Hmmm Random Multiple Misfire and Cylinder 4 misfire as well. P00300 isn't a single cylinder causing the issue to set this code. Yet it's not seeing enough to set more codes and clearly #4 is bad enough to set that particular code. Check the connection at the ICM. Was there any corrosion when you pulled the coils?
  5. #5 Re: Engine code p0304 and p0300
    Nov 2017
    Michigan
    Quote Originally Posted by BillBooost37 View Post
    No corrosion. I was getting p0300 regapped spark plugs now just getting p0304. If i pull wires off at the coils i get spark from each one. Im baffled at this point and it only happens at 65 to 70 mph after driving about 10 miles at that speed could it be caused by dirty injectors.
  6. #6 Re: Engine code p0304 and p0300
    Mar 2017
    Internet
    and you don't have an aftermarket camshaft?
  7. #7 Re: Engine code p0304 and p0300
    Nov 2017
    Michigan
    No everything is stock
  8. #8 Re: Engine code p0304 and p0300
    Nov 2013
    pittsfield ma. 01201
    Hey man just went through same thing lot of money wasted on trying different things end up being my downstream 02 sensor wish I tried this first would have saved a lot of money I changed both sensors they had 120000 on them.Dont know if this your problem but I was getting same codes.Good luck
  9. #9 Re: Engine code p0304 and p0300
    Nov 2017
    Michigan
    Quote Originally Posted by daviddawg View Post
    Damn yea i dont think i the downstream o2 sensor previous owner said someone tried stealing the cat and he straight piped it i know it has the upper o2 before the cat but idk about after
  10. #10 Re: Engine code p0304 and p0300
    St. Louis
    What type of plugs did you install, and are you sure you got all the wires in the right order? It's easy to mix up some wires and it'll still run. Been there, done that.
  11. #11 Re: Engine code p0304 and p0300
    Nov 2013
    After I replaced the down stream 02 sensor it took about a day of driving before problem went away
  12. #12 Re: Engine code p0304 and p0300
    Nov 2017
    Michigan
    Yea im missing the downstream 02 but i unplugged the one i do have seemed to be fine,this morning
  13. #13 Re: Engine code p0304 and p0300
    Nov 2017
    Michigan
    Quote Originally Posted by FordMan77 View Post
    Autolite platinums was real tight on cash and yes wires are in correct order
  14. #14 Re: Engine code p0304 and p0300
    Nov 2013
    One more thing before I replaced sensors car would run fine until it warmed up then I would start having the p0300 and p0304 codes
  15. #15 Re: Engine code p0304 and p0300
    May 2017
    Dirtyzville, Mizzery
    Quote Originally Posted by Aaron85 View Post
    You said coils too...
    Could be a simple mix up though still.
    Order of everything should be like this if you're standing in front of it...
    2 4 6
    1 3 5
    Coil order from top to bottom is
    6
    I'd also look into vacuum leaks. Usually you'd get a P0171 or something of the like but that can cause a misfire as well.
    I personally would have ran cheap ass Autolite 606 copper plugs. They should have been much cheaper than Platinum's. Gap them to .050". Done and done.
    By chance you didn't try to gap the platinum plugs, did you? lol
    1999 Chevrolet Silverado K1500 Classic Z71 - Intake/Gibson Exhaust/20% Tint
    2004 Chevrolet Corvette MRM A4 - C5Z Suspension/AFE S2 Intake/TSP Catless LT's/3" ORX/C6 ZR1 Wheels
    Sold WBody's: '98 GT, '98 GTP, '03 GTP, '05 GXP
  16. #16 Re: Engine code p0304 and p0300
    Nov 2017
    Michigan
    Quote Originally Posted by blueguy91 View Post
    2 4 6
    1 3 5
    6
    I did cuz i was told that they werent pre gapped. They are gapped to .045 right now
  17. #17 Re: Engine code p0304 and p0300
    Nov 2017
    Michigan
    I did 1 wire and plug at a time so i wouldnt mix them up also
  18. #18 Re: Engine code p0304 and p0300
    Nov 2017
    Michigan
    Yea it runs fine cold and once i drive 10 to 15 miles on highway at 70mph is,when it starts. I can drive main roads all day with no problem
  19. #19 Re: Engine code p0304 and p0300
    Mar 2017
    Internet
    That's way too small of a gap on the plugs.
  20. #20 Re: Engine code p0304 and p0300
    May 2017
    If they were the fine tipped plugs; then you most likely broke the wire up top on them. Yank all the plugs and check them. .045 is kinda small, too.
  1. P0300 code , need help !!
    By damohr in forum General Tech Discussion
    Last Post: 03-04-2015, 07:44 PM
  2. Code p0304 misfire 4
    By kcfalcon2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-15-2011, 02:21 PM
  3. Code p0304
    By gandprixgtpsuper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-09-2011, 08:24 AM
  4. p0304 code and engine overheating!!!!!!!
    By sinister1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-21-2011, 12:55 PM
  5. Check engine code: P0300?
    By CSteen85 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-02-2010, 11:45 AM
